call dzVent script as Selector Action. script:/// and then?
plugge
Post by plugge »
I'm trying to have a Selector (Type Switch, Selector Switch, Selector) call a dzVents script ("http://" works fine).
It should start with "script://" and is supposed to execute scripts in folder "scripts" beneath Domoticz.
(On Github I read that it should start with "script:///", three forward slashes)
How do I call a dzVents script in "generated_scripts"? (BTW: on a W10 machine)
I've tried several paths, but all I get is (f.e.)
SQLHelper: Error script not found '/dzVents\generated_scripts\tesyControl.lua'
I couldn't find it in neither the dzVents manual nor the forum.
Anyone succeeded doing this with dzVent scripts in the "generated_scripts" folder?
(Note: on a windows machine, i.e., backward slash)
TIA
Re: call dzVent script as Selector Action. script:/// and then?
plugge wrote: Sunday 07 March 2021 23:26 I'm trying to have a Selector (Type Switch, Selector Switch, Selector) call a dzVents script ("http://" works fine).
It is not possible to call a dzVents script like this nor needed. The dzVents script can be triggered natively by the update of the selector switch
See below example.
check the wiki for a complete description and howto
return
    on =
        devices =
            'name of your selector switch',
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'Selector actions',
    execute = function(dz, item)
        if item.levelName == 'level 1' then -- replace level 1 by the actual levelname
            -- do actions for level 1
        elseif item.levelName == 'level 2' then -- replace level 1 by the actual levelname
            -- do actions for level 2
        elseif item.levelName == 'level 3' then -- etc..
            -- etc
plugge
Re: call dzVent script as Selector Action. script:/// and then? [solved]
Post by plugge »
Ok, thanks.
