variable logging  [Solved]
pvklink
Domoticz version: latest b
variable logging
Post by pvklink »
Is this possible ?, to make the logging variable by a selector switch?
when this works i will put this in a global function
error
2021-01-16 20:50:43.092 Error: dzVents: Error: (3.1.1) ...icz/scripts/dzVents/generated_scripts/DZ_schakelklok.lua:61: attempt to call a nil value (field 'devices')
local function get_logtype()
    if (domoticz.devices('logtype').state == 'info') then       --(rule 61)
        local logtype = domoticz.LOG_INFO
    elseif (domoticz.devices('logtype').state == 'error') then
        local logtype = domoticz.LOG_ERROR
    elseif (domoticz.devices('logtype').state == 'debug') then
        local logtype = domoticz.LOG_DEBUG
    elseif (domoticz.devices('logtype').state == 'exec') then
        local logtype = domoticz.LOG_MODULE_EXEC_INFO
    return logtype
return
    on ={timer = get_active_timers(Timers),},
    logging ={level   = get_logtype()},
    execute = function(dz,item,info)
Jablotron connection, Ikea
Re: variable logging  [Solved]
pvklink wrote: Saturday 16 January 2021 18:45 Is this possible ?, to make the logging variable by a selector switch?
Yes, but not like you coded it.
This should work.
local function get_logtype(domoticz)
        return domoticz.LOG_INFO
        return domoticz.LOG_ERROR
        return  domoticz.LOG_MODULE_EXEC_INFO
    return domoticz.LOG_DEBUG
return
    on =
        timer =
            'every minute',
        _G.logLevel = get_logtype(dz)
        dz.log('debug test',dz.LOG_DEBUG) -- this will only make it to the log when LOG_DEBUG is set
        dz.log('blabla',dz.LOG_FORCE) -- this will allways make it tp the log
pvklink
Post by pvklink »
Ok, Thanks!
I am almost there to config my different kinds of logs and messages from within the userinterface (dashticz) with a selector.
pvklink
Post by pvklink »
everything works PERFECT !!
many thanks...(@waaren)
