Script limit notifications  [Solved]
Nefsolive
Post by Nefsolive »
the script I send below, verifies an energy value and sends a message by pushover.
The problem is that if the value is always above, every minute sends a notification! Is there any way to send in this script for example, 3 notifications max ? And not minute by minute.
Ty
    on =
        timer =
            'every minute',
    execute = function(domoticz)
        local floatFormat =  '%d*%.*%d*'
        local rawEnergiaConsumida = domoticz.devices('Energia Consumida').rawData[1]
        local EnergiaConsumida = tonumber(string.match(rawEnergiaConsumida, floatFormat))
        if EnergiaConsumida >= 3200 then
            local textmensagem = "A voltagem " .. EnergiaConsumida .. " Watt, está muito ALTA! O disjuntor pode disparar!"
                    domoticz.notify("⚡ VOLTAGEM ELECTRICA", textmensagem , domoticz.PRIORITY_HIGH, domoticz.SOUND_COSMIC, "" , domoticz.NSS_PUSHOVER)
Re: Script limit notifications
Nefsolive wrote: Friday 15 January 2021 19:22 the script I send below, verifies an energy value and sends a message by pushover.
One way to solve that is in below example
    on =
        timer =
            'every minute',
    data =
        notificationCounter =
            initial = 0,
        lastNotification =
            initial = 0,
       if EnergiaConsumida >= 3200 and ( domoticz.data.lastNotification < ( os.time() + 900 )) then -- max once per 15 minutes
            domoticz.data.lastNotification = os.time()
            domoticz.data.notificationCounter = domoticz.data.notificationCounter + 1
            if domoticz.data.notificationCounter > 3 then
                domoticz.data.lastNotification = os.time() + 3600 * 12 -- Delay next message for 12 hours
                domoticz.data.notificationCounter = 0
Nefsolive
Post by Nefsolive »
waaren wrote: Friday 15 January 2021 20:46
    on =
        timer =
            'every minute',
    data =
            initial = 0,
        lastNotification =
            initial = 0,
Hello Waaren,
thanks for your reply!
I try and i have this error on log;
scripts/dzVents/generated_scripts/Msg Potência Watt.lua:27: attempt to perform arithmetic on a function value (field 'time')
Nefsolive wrote: Friday 15 January 2021 22:00 I try and i have this error on log;
If you change os.time to os.time() it should work.
Nefsolive
Re: Script limit notifications  [Solved]
Post by Nefsolive »
waaren wrote: Friday 15 January 2021 22:03
Waaren thanks,
os.time() Works!
And script, works like a charm!
Ty for always helping.
