QueuedCommand on selector switch not executing  [Solved]
James83
Post by James83 »
I noticed a strange behavior since beta 12501 and still exists in latest beta 12709 but i believe it worked fine in 12497
I have 2 scripts. First triggered script contains these lines:
if checkmks then dz.devices('Alarm').switchSelector('Check MKs').afterSec(1) end -- check MK's uitvoeren
if alarmschakelen then dz.devices('Alarm').switchSelector(alarmmodus).afterSec(5) end -- Alarm inschakelen
The result of the first line triggers another script "Check MKs" which contains the line:
dz.devices('Alarm').switchSelector(0).afterSec(1).silent()
So far, so good
Then the second line of the first script should change the state of the selector switch again after 5 sec but it doesn't. No errors, just not switching.
It looks like the queud command 'afterSec(5)' is forgotten by DzVents
But if i disable the line of the second script, then the second line of the first script does switch the selectorswitch after 5sec.
Also tried without the "afterSec" and "silent" but didn't help.
I could not find any related changes in the latest beta's.
What could cause this behavior?
RPI4, Philips Hue, Tradfri, Sonoff, MQTT, Zigbee2Mqtt, RFXCom 433, Octoprint,...
Re: QueuedCommand on selector switch not executing  [Solved]
James83 wrote: Thursday 03 December 2020 22:21 The result of the first line triggers another script "Check MKs" which contains the line:
If this code is send to domoticz it will cancel all outstanding switchSelector commands for this device send by earlier scripts.
If it worked before then the scripts involved were processed in the same batch of dzVents scripts and returned to domoticz in one and the same commandArray (and therefore all switchSelector().afterSec() are scheduled and not canceled)
