Problem writing value in custom sensor  [Solved]
dutchronnie
Post by dutchronnie »
I have an IBC filled with water, and want to see the following
filled in %
how many liters
I get the distance and percentage in domoticz, but i am not able to see the amount of liters.
i am using the following script
                devices =   {
                                'Niveau Regenwater'
   logging = {
                level = domoticz.LOG_INFO,
                marker = "Converter"
    execute = function(dz, item)
        local inverted              = false          -- if max value of sensor should be reflected in 0% and minValue in 100%
        local dataFromSensor        = item.rawData[1]
        local maxValue              = 920
        local minValue              = 0
        local decimals              = 0
        local percentage            = ( dataFromSensor - minValue ) / ( maxValue - minValue ) * 1000
        local liters                = ( dataFromSensor * 0.92 )
        if inverted then
               percentage = 100 - percentage
        local roundedPercentage     = dz.utils.round(percentage,decimals )
        local percentageDevice      = dz.devices('Percentage IBC gevuld')
        local roundedLiters         = dz.utils.round(liters,decimals )
        local litersDevice          = dz.devices('Liters')
        dz.log("Rounded percentage is " ..  roundedPercentage .. "%")
        percentageDevice.updatePercentage(roundedPercentage)
        dz.log("Rounded liters is " ..  roundedLiters .. "Ltr")
        litersDevice.update(roundedLiters)
In the log i see that the ibc is filed for 23%
and that the amount of liters is: 19 Liter
but the value is not writen in the custom sensor
I hope somebody can help
Re: Problem writing value in custom sensor
dutchronnie wrote: Thursday 05 November 2020 14:26
Please search the wiki
The method to update a custom Sensor is.... updateCustomSensor(value)
dutchronnie
Re: Problem writing value in custom sensor  [Solved]
Thanks, That was the solution.
