Timer switch error 32256  [Solved]
Dutchsea
Domoticz version: v2023.2
Post by Dutchsea »
I created a simple script to deactivate a device after x amount of time after it has beentriggered in the domoticz dashboard.
(script is called via the "On action:" in the "Edit" page of the device).
Its purpose is to deactivate a heater in my bathroom after it has been activated via the Domoticz dashboard. Not sure if the script is a good method to deactivate the device. Maybe there is a better way but this is what I could think of.......
The script works but when it is activated it generates an error 32256. This seems to be an ownership issue but this script has the same ownerships as my other dzVents scripts and those do not generate this error.
Script:
-- [ dzVents >= 2.4 ]
-- dzVents Timer: set device to off after x minutes after on
-- script://dzVents/scripts/timer01-on.lua
--- Script active yes/no
    active = {
    	true,
--- Trigger device
    	devices = {
	'Kachel badkamer' -- Device to be turned off after x minutes
--- Custom logging for script
    logging = {
    	level = domoticz.LOG_DEBUG,
	marker = "Timer01-on"
--- Execute functions
    	    domoticz.devices('Kachel badkamer').switchOff().afterMin(2) -- change x in .afterMin(x) to number of minutes required
What can cause this error?
Next question; even when the device 'Kachel badkamer' is not activated, every minute there are entries in the log. So for some reason each minute this scripts is activated. Is this expected behaviour?
Log
2020-10-31 20:42:16.616 Status: dzVents: Info: Handling events for: "Kachel badkamer", value: "Off"
2020-10-31 20:42:16.616 Status: dzVents: Info: Timer01-on: ------ Start external script: timer01-on.lua: Device: "Kachel badkamer (Aeon Z-stick 5Gen)", Index: 3
2020-10-31 20:42:16.616 Status: dzVents: Debug: Timer01-on: Constructed timed-command: Off
2020-10-31 20:42:16.616 Status: dzVents: Debug: Timer01-on: Constructed timed-command: Off AFTER 120 SECONDS
2020-10-31 20:42:16.616 Status: dzVents: Info: Timer01-on: ------ Finished timer01-on.lua
2020-10-31 20:42:16.617 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
Re: Timer switch error 32256  [Solved]
Dutchsea wrote: Saturday 31 October 2020 20:49 I created a simple script to deactivate a device after x amount of time after it has been triggered in the domoticz dashboard.
Lua / dzVents scripts should not be called via the action fields of a device. This is to be used for external (OS type of) scripts.
The action you are looking for can be done without any script. Just set the off delay in the edit screen of the device. (from the switches tab)
Dutchsea
Post by Dutchsea »
=> clear
OK, i will do that. (I understood these parameters to control the amount of delay in seconds before turning on the device after it has been triggered to go on - and same delay when device is triggered to go off.)
Dutchsea
SOLVED Timer switch error 32256
Post by Dutchsea »
And works. Thank you
