Presence detection  [Solved]
Cndiann
Presence detection
Post by Cndiann »
I have made a system alive young device for my mobile phone. I have set the correct mac and IP address, so domoticz does ping my phone correct.
Now I would like to when I come home the scene 'woonkamer aan' will be activated after sunset when my phone connects to the Wifi.
But when I would like to set a other scene, for example 'watch movie' I want to overrule the presence detection. So when I decided to turn off wifi on phone and after half hour turn wifi on the lights will not set back to 'woonkamer aan'.
Is it possible to run the detection script again only after scene 'all lights out' has been activated? So that when I get home the detection script starts again?
Re: Presence detection
Cndiann wrote: Tuesday 20 October 2020 0:58 ...
Sure, it's possible..
My approach to this would be to separate the required functionality into different scripts.
One script to identify presence of phones on wifi and have this script communicate that state by using a customEvent or using Global persistent data-, a uservariable or a dummy device.
One script to identify switching of 'watch movie' (and/or other scenes) and have this script communicate that state using Global persistent data-, a uservariable or a dummy device.
One script to switch the scene 'Woonkamer aan' after checking time / presence state / scene state.
Cndiann
Post by Cndiann »
Thank you. For the first script I have made a dummy switch and set my phone as a sub slave device, so the dummy switch works.
But the other 2 script, I'm totally new with lua or dzvents. I have tried the search function for similar scripts but can't find one.
Cndiann wrote: Wednesday 21 October 2020 9:37 Thank you. For the first script I have made a dummy switch and set my phone as a sub slave device, so the dummy switch works.
Will try to come with an example but might take some time.
Initial version (I combined 2nd 3rd script into 1)
-- One script to switch the scene 'Woonkamer aan' after checking time / presence state / scene state.
local blockingScenes =
    'watch movie',
    'watch tv',   -- example to show you can have multiple blocking scenes
local blockingGroups =
    'romantic lights', -- Scenes and groups are distinct so need to be addressed separate
    'another Group',
local myPhone = 'name of Phone Switch' -- change to name of dummy switch
return
    on =
        scenes = blockingScenes, -- if one or more of these scenes / groups are activated after sunset
        groups = blockingGroups, -- the switchingScene will be blocked until next sunset
        timer =
            'at sunset',
            'at sunrise',
        devices =
            myPhone,
    data =
        blockers =
            initial = {},
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'scene Control',
    execute = function(dz, item)
        local switchingScene = dz.scenes('woonkamer aan') -- change to name of your switchingScene
        local phoneAtHome = dz.devices(myPhone).active
        local function switchAllowed(t)
            for scene, blocked in pairs(t) do
                if blocked then
                    dz.log(scene .. ' is blocking the switch', dz.LOG_DEBUG)
                    return false
            return true
        if item.isScene or item.isGroup and item.state ~= 'Off' and dz.time.matchesRule('between sunset and 23:59') then
            dz.data.blockers[item.name] = true
            return
        if item.isTimer and dz.time.matchesRule('at sunrise') then
           dz.data.blockers = {} -- reset blockers
           return
        if phoneAtHome and dz.time.matchesRule('between sunset and 23:59') then -- This will be evaluated at sunset and when the phone becomes active after sunset
            if switchAllowed(dz.data.blockers) then
                switchingScene.switchOn()
Cndiann
Re: Presence detection  [Solved]
Post by Cndiann »
Thanks the script is working!!
I have only 2 phones as a dummy, is this script correct? Does it work when only 1 phone is active? And when the second phone comes home does it not overrule the script?
Is it possible to reset the script when for example scene leaving home is activated?
'Film kijken',
'Film kijken', -- Scenes and groups are distinct so need to be addressed separate
local myPhone =
{ 'Telefoon 1',
'Telefoon 2',-- change to name of dummy switch
return
on =
timer =
'at sunset',
'at sunrise',
devices =
myPhone,
data =
blockers =
initial = {},
logging =
level = domoticz.LOG_ERROR, -- change to domoticz.LOG_ERROR when all OK
local switchingScene = dz.scenes('Woonkamer aan') -- change to name of your switchingScene
if blocked then
return false
return true
return
return
Cndiann wrote: Friday 23 October 2020 15:09 I have only 2 phones as a dummy, is this script correct?
Your modification will not work. What did you do to test it ?
Below modified script will check all phones and if one or more are active it will continue. The blocking will still be active when a next phone becomes active
Can you please explain what you mean with "reset the script"?
    'watch movie',
    'another Group',
local myPhones =      -- change to names of all dummy switch
    'name of Phone Switch1',
    'name of Phone Switch2',
return
    on =
        devices = myPhones,
        timer =
            'at sunset',
            'at sunrise',
    data =
        blockers =
            initial = {},
    logging =
        local function phoneActive(t)
            for _, phone in ipairs(t) do
                if dz.devices(phone).active then
                    return true
                if blocked then
                    return false
            return true
            return
           return
        if phoneActive(myPhones) and dz.time.matchesRule('between sunset and 23:59') then -- This will be evaluated at sunset and when a phone becomes active after sunset
Cndiann
Post by Cndiann »
Thanks I will test it when I'm at home.
If I want to leave the house for example at 22:00 I switch off all the lights. And when I come home at 23:00 I want to start the script again so it does switch Woonkamer aan.
But now it only does after midnight.
Cndiann wrote: Friday 23 October 2020 16:27 If I want to leave the house for example at 22:00 I switch off all the lights. And when I come home at 23:00 I want to start the script again so it does switch Woonkamer aan.
OK,
something like this? (untested)
    'watch movie',
    'another Group',
local resets =
    'leaving home',
local function mergeArrays(t1, t2)
    local t3 = {}
    for _,v in ipairs(t1) do  table.insert(t3, v) end
    for _,v in ipairs(t2) do  table.insert(t3, v) end
    return t3
allScenes = mergeArrays(blockingScenes, resets)
allGroups = mergeArrays(blockingGroups, resets)
return
    on =
        scenes = allScenes, -- if one or more of the blocking scenes / groups are activated after sunset
        groups = allGroups, -- the switchingScene will be blocked until next sunset. If a resets scene / group then the block is lifted
        devices = myPhones,
        timer =
            'at sunset',
            'at sunrise',
    data =
        blockers =
            initial = {},
    logging =
                    return true
                if blocked then
                    return false
            return true
        function isReset(scene)
            for _, v in ipairs(resetScenes)do
                if v == scene then
                    return true
            return false
            if isReset(item.name) then
            return
           return
Cndiann
Post by Cndiann »
Thanks for the script! It does seems half to work. When the script activates Woonkamer aan, and after that I set the scene Film kijken on then when I disconnect from wifi and get back on wifi the script starts Woonkamer aan again.
And even when phone 1 is on and I have set scene Film kijken on and Phone 2 comes home the script will turn Woonkamer aan on.
I also get this error:
020-10-23 20:58:41.907 Error: dzVents: Error: (3.0.2) scene Control: An error occurred when calling event handler Telefoon
2020-10-23 20:58:41.907 Error: dzVents: Error: (3.0.2) scene Control: .../domoticz/scripts/dzVents/generated_scripts/Telefoon.lua:88: bad argument #1 to 'ipairs' (table expected, got nil)
I use this script
    'Film kijken',  -- example to show you can have multiple blocking scenes
    'Telefoon 1',
    'Telefoon 2',
local resets =
    'Niet thuis',
    local t3 = {}
    return t3
return
    on =
        devices = myPhones,
        timer =
            'at sunset',
            'at sunrise',
    data =
        blockers =
            initial = {},
    logging =
                    return true
                if blocked then
                    return false
            return true
                if v == scene then
                    return true
            return false
            return
           return
Cndiann wrote: Friday 23 October 2020 21:04 I also get this error:
First solve this error before checking again; change the string "resetScenes" to "resets"
Cndiann
Post by Cndiann »
I have changed it to
            for _, v in ipairs(reset)do
                if v == scene then
                    return true
The scene Woonkamer aan starts when I turn on wifi on my phone. But if I then choose scene Film kijken, turn off Wifi and turn Wifi back on the scene Woonkamer aan starts.
2020-10-23 23:56:36.174 Status: User: ***** initiated a scene/group command
2020-10-23 23:56:36.300 Status: dzVents: Info: Handling events for: "Film kijken", value: "On"
2020-10-23 23:56:36.300 Status: dzVents: Info: scene Control: ------ Start internal script: Telefoon: Scene: "Film kijken", Index: 1
2020-10-23 23:56:36.301 Status: dzVents: Debug: scene Control: Processing device-adapter for Woonkamer aan: Scene device adapter
2020-10-23 23:56:36.301 Status: dzVents: Info: scene Control: ------ Finished Telefoon
2020-10-23 23:56:36.301 Status: dzVents: Info: scene Control: ------ Start internal script: Telefoon: Scene: "Film kijken", Index: 1
2020-10-23 23:56:36.302 Status: dzVents: Info: scene Control: ------ Finished Telefoon
2020-10-23 23:56:36.301 Error: dzVents: Error: (3.0.2) scene Control: An error occurred when calling event handler Telefoon
2020-10-23 23:56:36.301 Error: dzVents: Error: (3.0.2) scene Control: .../domoticz/scripts/dzVents/generated_scripts/Telefoon.lua:88: bad argument #1 to 'ipairs' (table expected, got nil)
2020-10-23 23:56:36.302 Error: dzVents: Error: (3.0.2) scene Control: .../domoticz/scripts/dzVents/generated_scripts/Telefoon.lua:88: bad argument #1 to 'ipairs' (table expected, got nil)
Cndiann
Post by Cndiann »
Edit;
It works now! I was forgot the -s! Resets instead of reset.
Many thanks!
Cndiann
Post by Cndiann »
Sorry to open again.
But I doesn't reset the script after sunrise and doesn't activate next sunset.
I first have to start the scene 'niet thuis' then it reset the script
Cndiann
Post by Cndiann »
This is my current script. I want the script active after sunset till 02:00. Afther 02:00 it needs to reset so it will be activated at next sunset.
The problem now is the script doens't reset after 02:00 and be active next sunset, only when I have switch the scene 'Niet thuis'
    'Telefoon Stefan',
    'Telefoon Sigrid',
local resets =
    'Niet thuis',
    local t3 = {}
    return t3
return
    on =
        devices = myPhones,
        timer =
            'at sunset',
            'at 02:00',
    data =
        blockers =
            initial = {},
    logging =
                    return true
                if blocked then
                    return false
            return true
            for _, v in ipairs(resets)do
                if v == scene then
                    return true
            return false
        if item.isScene or item.isGroup and item.state ~= 'Off' and dz.time.matchesRule('between sunset and 02:00') then
            return
        if item.isTimer and dz.time.matchesRule('at 02:00') then
           return
        if phoneActive(myPhones) and dz.time.matchesRule('between sunset and 02:00') then -- This will be evaluated at sunset and when a phone becomes active after sunset
EDIT I gues it's working now, I will let you know tomorrow.
Cndiann wrote: Sunday 25 October 2020 18:23 This is my current script. I want the script active after sunset till 02:00. Afther 02:00 it needs to reset so it will be activated at next sunset.
[EDIT] I guess it's working now, I will let you know tomorrow.
Best to add some extra debug loglines in the script so you can quickly see what flow the code follows. That will make it easier to identify issues
By setting the log level to domoticz.LOG_ERROR you won't get the debug lines in your log during normal use.
like
    'Telefoon Stefan',
    'Telefoon Sigrid',
local resets =
    'Niet thuis',
    local t3 = {}
    return t3
return
    on =
        devices = myPhones,
        timer =
            'at sunset',
            'at 02:00',
    data =
        blockers =
            initial = {},
    logging =
        if not(item.isTimer) then
            dz.log(item.name .. '( a ' .. item.baseType .. ') triggered the script. State is ' .. item.state , dz.LOG_DEBUG )
                    return true
            dz.log('-- debug phoneActive' , dz.LOG_DEBUG )
                if blocked then
                    return false
            dz.log('-- debug switchAllowed ', dz.LOG_DEBUG )
            return true
                if v == scene then
                    return true
            dz.log('-- debug isReset ', dz.LOG_DEBUG )
            return false
            dz.log('-- debug 1' , dz.LOG_DEBUG )
                dz.log('-- debug 2' , dz.LOG_DEBUG )
            return
            dz.log('-- debug 3' , dz.LOG_DEBUG )
           return
            dz.log('-- debug 4' , dz.LOG_DEBUG )
                dz.log('-- debug 5' , dz.LOG_DEBUG )
Cndiann
Post by Cndiann »
Script is working perfectly! Thanks again.
Nateonas
Domoticz version: 2024.4
Post by Nateonas »
Since I could not find a simple solution for IP presence detection on Domoticz, I wrote one myself. It only requires a single dzVentz script, dzPresence. It uses simple ping shell commands and supports any number of devices. You can also create an "anyone home"-switch.
See: https://github.com/Nateonas/Domoticz_Dz ... eDetection
Enjoy!
Perhaps anyone can (tell me how to) update the outdated Domoticz Presence Detection Wiki (https://www.domoticz.com/wiki/Presence_detection), than I'm happy to know!
