control heating with doorsensor  [Solved]
madpatrick
Domoticz version: 2025.2
Post by madpatrick »
I'm trying to write a simple scripy with Blocky to switch of the heating when the door is open.
Unfortunately Blocky doesn't the functionality to set the heatingpoint with a UserVariable.
Can somebody help me with this or help with some programming in LUA or Dzvent
Re: control heating with doorsensor
madpatrick wrote: Tuesday 06 October 2020 18:54 Hi,
Something like this?
btw. I used dzVents persistent data to save the setPoint. Let me know if you really need in a domoticz uservariable.
return
    on =
        devices =
            'Sensor - Achterdeur', -- Did I set the spaces in the name OK?
    data =
        lastSetpoint =
            initial = -99,
    logging =
        level = domoticz.LOG_DEBUG, -- change to LOG_ERROR when all OK
        marker = 'Heating control',
    execute = function(dz, item)
        local toon = dz.devices('Toon Thermostaat')
        dz.log('Contact ' .. item.name .. ' state is ' .. item.state, dz.LOG_DEBUG)
        if item.state == 'Open' and dz.data.lastSetpoint == -99 then
            dz.data.lastSetpoint = toon.setPoint
            toon.updateSetPoint(15)
        elseif item.state ~= 'Open' and dz.data.lastSetpoint ~= -99 then
            toon.updateSetPoint(dz.data.lastSetpoint)
            dz.data.lastSetpoint = -99
madpatrick
Hi Waanen,
Thank you very much for your swift reply and support
I don't need a uservariable, but i thought this is the way to store the setpoint.
The script works great !!
I also like to have timer of 10 seconds before the heating is set off when the door is open
madpatrick wrote: Wednesday 07 October 2020 9:31 The script works great !!
That complicates it a bit because the last time I checked afterSec() did not work for setting a thermostat. To work around that I added a customEvents trigger.
Can you try this?
local scriptVar = 'heatingControl'
local doorContact = 'Sensor - Achterdeur'  -- Did I set the spaces in the name OK?
return
    on =
        devices =
            doorContact,
        customEvents =
            scriptVar,
    data =
        lastSetpoint =
            initial = -99,
    logging =
        marker = scriptVar,
        local delay = 10
        local door = dz.devices(doorContact)
        if item.isDevice then
                dz.emitEvent(scriptVar).afterSec(delay)
            if door.state == 'Open' and dz.data.lastSetpoint == -99 then
madpatrick
Re: control heating with doorsensor  [Solved]
Hi Waaren,
This is also working !
I'll tested it the next days more in detail
Thanks very much for your effort !
MJAvH
Post by MJAvH »
Hi Waaren,
Thank you for your script, also works for me! :)
Small question: If the door/window is still open and "somebody or a scheduled task" will change set point on thermostat, what could be done to reinforce the value again to 15°C?
I tryed like that but without success :-( with another elseif:
        local delay = 10
            elseif door.state == 'Open' and toon.setPoint ~= 16 then
                dz.log('!!!DEBUG only, when last elseif was called' , dz.LOG_DEBUG)
Thx for your advice
