Thanks! Much appreciated!waaren wrote:You can withjake wrote: Monday 31 August 2020 18:59 Although I can now continue my script, I would like to know out of curiosity how I could still show the 'false' in a log line, instead of domoticz failing with 'attempt to concatenate a boolean value'orCode: Select all
print("The result true or false from the request is ".. tostring(json.result['Player.HasAudio']))Code: Select all
domoticz.log("The result true or false from the request is ".. tostring(json.result['Player.HasAudio']), domoticz.LOG_FORCE)
dzVents OpenURL json to LUA how to read [Solved]
jake
Re: dzVents OpenURL json to LUA how to read [Solved]
