I've only 2 scripts Enabled (for the test I've Disabled all other scripts to be sure)
One that toggle 2 dummy switches
local LIGHTS= {460, 202}
on = {timer = { "every minute" }
logging = {level = domoticz.LOG_DEBUG,
execute = function(dz, item)
_G.logMarker = dz.moduleLabel -- set logmarker to scriptname
local LOG_LEVEL = dz.LOG_DEBUG -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE
local zwaveDevice
for i, d in ipairs(LIGHTS) do
zwaveDevice = dz.devices(d)
if not zwaveDevice.active then
zwaveDevice.switchOn().afterSec(i)
dz.log(d .. ' Device: '.. zwaveDevice.name .. " : " .. zwaveDevice.id .. " : " .. zwaveDevice.state .. " to ON", LOG_LEVEL)
zwaveDevice.switchOff().afterSec(i)
dz.log(d .. ' Device: '.. zwaveDevice.name .. " : " .. zwaveDevice.id .. " : " .. zwaveDevice.state .. " to OFF", LOG_LEVEL)
} Code: Select all
local LIGHT = {1023}
devices = LIGHT
execute = function(dz, device)
local LOG_LEVEL = dz.LOG_DEBUG -- LOG_INFO, LOG_DEBUG, LOG_ERROR, LOG_FORCE - normal = LOG_INFO
dz.log('Device TRIGGERED ' .. device.id .. ' ' .. device.name .. ' '.. device.state .. ' ' .. device.deviceType, dz.LOG_ERROR)
}the log is the following
2020-07-01 22:10:00.390 Status: dzVents: Info: ------ Start internal script: zTestOn:, trigger: "every minute"
2020-07-01 22:10:00.407 Status: dzVents: Debug: zTestOn: Processing device-adapter for test inter 460: Switch device adapter
2020-07-01 22:10:00.407 Status: dzVents: Debug: zTestOn: Constructed timed-command: On
2020-07-01 22:10:00.408 Status: dzVents: Debug: zTestOn: Constructed timed-command: On AFTER 1 SECONDS
2020-07-01 22:10:00.408 Status: dzVents: Debug: zTestOn: 460 Device test inter 460 : 460 : Off to ON
2020-07-01 22:10:00.410 Status: dzVents: Debug: zTestOn: Processing device-adapter for test detecteur 202: Switch device adapter
2020-07-01 22:10:00.411 Status: dzVents: Debug: zTestOn: Constructed timed-command: On
2020-07-01 22:10:00.411 Status: dzVents: Debug: zTestOn: Constructed timed-command: On AFTER 2 SECONDS
2020-07-01 22:10:00.411 Status: dzVents: Debug: zTestOn: 202 Device test detecteur 202 : 202 : Off to ON
2020-07-01 22:10:00.411 Status: dzVents: Info: zTestOn: ------ Finished zTestOn
2020-07-01 22:10:00.414 Status: EventSystem: Script event triggered: /home/pi/PROD_domoticz/dzVents/runtime/dzVents.lua
2020-07-01 22:10:01.472 (Dummy1) Light/Switch (test inter 460)
2020-07-01 22:10:01.632 Status: dzVents: Info: ------ Start internal script: zTestTriggered: Device: "s/Balcon (Z-Wave Plus Z-Stick Gen5)", Index: 1023
2020-07-01 22:10:01.633 Status: dzVents: Info: zTestTriggered: ------ Finished zTestTriggered
2020-07-01 22:10:01.633 Error: dzVents: Error: (3.0.9) zTestTriggered: Device TRIGGERED 1023 s/Balcon On Light/Switch
2020-07-01 22:10:02.472 (Dummy1) Light/Switch (test detecteur 202)
2020-07-01 22:10:06.550 (Dummy1) Light/Switch (test inter 460)
2020-07-01 22:10:06.771 Status: dzVents: Info: ------ Start internal script: zTestTriggered: Device: "s/Balcon (Z-Wave Plus Z-Stick Gen5)", Index: 1023
2020-07-01 22:10:06.772 Status: dzVents: Info: zTestTriggered: ------ Finished zTestTriggered
2020-07-01 22:10:06.772 Error: dzVents: Error: (3.0.9) zTestTriggered: Device TRIGGERED 1023 s/Balcon Off Light/SwitchVersion: 2020.2 (build 12192)
Build Hash: 8f82b73ff-modified
Compile Date: 2020-06-29 16:15:42
dzVents Version: 3.0.9
