How to change the volume of the amixer With a virtual dimmer [Solved]
I have domoticz v 2020.2 beta current RPI, dzVents Version: 3.0.8
I use a USB audio card where I do volume control using the selector and sh scripts
#!/bin/bash
amixer sset 'Speaker' 2dB+
#!/bin/bash
amixer sset 'Speaker' 2dB-
or
amixer sset 'Speaker' 0% - selector - level 1
amixer sset 'Speaker' 100% - selector - level 10
How to change the volume of the amixer With a virtual dimmer.
What is the best way to do this ; amixer sset Speaker value to virtual dimmer%
Of course, it's best at dzVents
thank you for your help
#!/bin/bash
#!/bin/bash
or
- waaren
Re: How to change the volume of the amixer With a virtual dimmer
Can you check if the dzVents command os.execute("amixer sset 'Speaker' 2dB+") does work ?
That's how it works
devices = {'Button'}
logging =
level = domoticz.LOG_DEBUG,
marker = 'Volume up button ',
execute = function(dz, device)
if (device.state == 'On' ) then
dz.log ('volume up +2dB')
- waaren
And what is the range of the dB+ and dB- ?
In other words if the slider of the dimmer goes from 0 to 100 how much should the dB do ?
Speaker [dB gain: -45,00, -45,00] - mute 0%
Speaker [dB gain: 0,00, 0,00] - full 100%
if gain = -45 and amixer sset 'Speaker' 2dB+
set gain = -43
I hope it's readable
set gain = -43
- waaren
So 100 = 0 and -45 = 0 ?
Is my conclusion that every 100/45 point of the dimmer is 1 dB correct ?
Yes, this is it
I changed sh scripts to one dzVents script and it works
However, this does not give as much opportunity as a dimmer
devices = {'Volume'} -- Name of the dummy Domoticz selector
logging =
marker = 'Volume control ',
local vol = dz.devices('Volume')
if vol.state == 'Off' then
os.execute('mpc pause')
dz.log ('volume mute')
elseif vol.state ~= 'Off' then
os.execute('mpc play')
dz.log ('Set volume to selector level')
if vol.state == '25%' then
os.execute("amixer sset 'Speaker' 25%")
elseif vol.state == '27%' then
os.execute("amixer sset 'Speaker' 27%")
elseif vol.state == '30%' then
os.execute("amixer sset 'Speaker' 30%")
elseif vol.state == '35%' then
os.execute("amixer sset 'Speaker' 35%")
elseif vol.state == '40%' then
os.execute("amixer sset 'Speaker' 40%")
elseif vol.state == '45%' then
os.execute("amixer sset 'Speaker' 45%")
elseif vol.state == '60%' then
os.execute("amixer sset 'Speaker' 61%")
elseif vol.state == '70%' then
os.execute("amixer sset 'Speaker' 70%")
elseif vol.state == '80%' then
os.execute("amixer sset 'Speaker' 80%")
elseif vol.state == '95%' then
os.execute("amixer sset 'Speaker' 95%")
- waaren
can you try this after setting up a virtual dimmer in domoticz
return
on =
devices =
'Dimmer', -- Name of the virtual dimmer
logging =
execute = function(dz, item)
local percentage = 0
if item.state == 'Off' then
return
elseif item.state == 'On' then
percentage = 95
percentage = item.level
dz.log ('volume to ' .. percentage .. '%',dz.LOG_DEBUG)
os.execute("amixer sset 'Speaker' " .. tostring(percentage) .. "%")
Thank you for your help, but it doesn't work ok.
I added the mpc play command because dimmer did not start playback.
The script works so that it always sets the value of percentage max
no matter where the slider is
Record in Log
Here max 95 as you did
And Log
return
percentage = 40
2020-06-02 14:25:41.210 Status: dzVents: Info: Volume control : volume mute
2020-06-02 14:25:41.210 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:45.941 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:45.963 Status: dzVents: Info: Volume control : volume mute
2020-06-02 14:25:45.963 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:48.814 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:48.844 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:48.871 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:50.993 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:51.016 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:51.051 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:52.715 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:52.737 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:52.763 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:54.105 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:54.128 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:54.158 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:55.345 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:55.368 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:55.401 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:25:56.650 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:25:56.672 Status: dzVents: Debug: Volume control : volume to 40%
2020-06-02 14:25:56.698 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
percentage = 95
2020-06-02 14:54:00.174 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Volume dimmer.lua
2020-06-02 14:54:12.030 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:12.064 Status: dzVents: Info: Volume control : volume mute
2020-06-02 14:54:12.064 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:15.143 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:15.176 Status: dzVents: Debug: Volume control : volume to 95%
2020-06-02 14:54:15.205 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:16.162 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:16.185 Status: dzVents: Debug: Volume control : volume to 95%
2020-06-02 14:54:16.212 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:16.833 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:16.862 Status: dzVents: Debug: Volume control : volume to 95%
2020-06-02 14:54:16.890 Status: dzVents: Info: Volume control : ------ Finished Volume dimmer
2020-06-02 14:54:17.637 Status: dzVents: Info: Volume control : ------ Start internal script: Volume dimmer: Device: "Głośność (Pomocnicze)", Index: 320
2020-06-02 14:54:17.668 Status: dzVents: Debug: Volume control : volume to 95%
- waaren
Can you try with this one ?
return
on =
devices =
logging =
item.dimTo(1).silent()
item.dimTo(0).silent().afterSec(1)
local percentage = item.level
os.execute("mpc play; sleep 1; amixer sset 'Speaker' " .. tostring(percentage) .. "%")
Now works in the slider range.
The level change works with a second delay but it is probably by sleep 1? I have a question
Why when the dimmer is OFF need to set the dimmer to 1 and per second to 0
Second question After setting the dimmer to OFF and then He is always 1% level Does it have to be this way?
Third question. If you delete the mpc play and pausa commands, you can eliminate delays?
Many thanks for your time and help
- waaren
Answer 1+2: If you don't do this the slider will stay on the last level ==>> visual confusingbesix wrote: ↑Tuesday 02 June 2020 18:38 Now works in the slider range.
Yes, the sleep is only to ensure that the volume command does not interfere with the play.Third question. If you delete the mpc play and pausa commands, you can eliminate delays?
Just experiment without it and you will see if it keeps working. I cannot test because I don't own the hardware.
Thank you again !
Re: How to change the volume of the amixer With a virtual dimmer [Solved]
Without mpc play support, pause Works as I wanted
You were very helpful
