Merge  [Solved]
Larsoss
Merge
Post by Larsoss »
I use Telegram to send me information about consumption and power generation at certain times. Now I get 7 separate Telegram messages about this, which are also not sent in the correct order as in the script.
My question is actually can I also combine these? So that I get 1 message from revival with 2 different pieces of information. (high Low)
  dz.notify(subject, 'Terug levering Hoog ' ..vandaagKwhth.. ' kWh', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
  dz.notify(subject, 'Terug levering Laag ' ..vandaagKwhtl.. ' kWh', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
  dz.notify(subject, 'Verbruik Hoog ' ..vandaagKwhvh.. ' kWh', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
  dz.notify(subject, 'Verbruik Laag ' ..vandaagKwhvl.. ' kWh', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
  dz.notify(subject, 'Totaal Opbrengst Zonnepanelen ' ..vandaagSolar.. ' kWh', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
  dz.notify(subject, 'Totaal Verbruik Elektra vandaag ' ..vandaagKwh.. ' kWh', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
  dz.notify(subject, 'Totaal Verbruik Gas vandaag ' ..vandaagm3.. ' M3', dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
Raspberry 4 - USB boot Domoticz /|\ Raspberry 2B - Dashticz /|\ Tasmota device's /|\ Philips Hue & Yeelight
Re: Merge  [Solved]
Larsoss wrote: Thursday 14 May 2020 20:02 I use Telegram to send me information about consumption and power generation at certain times. Now I get 7 separate Telegram messages about this, which are also not sent in the correct order as in the script.
Can I also combine these? So that I get 1 message from revival with 2 different pieces of information. (high Low)
Something like below will combine these lines and send as one message.
local subject = 'my Energy overview'
local message = 'Terug levering Hoog ' ..vandaagKwhth.. ' kWh' .. '\n' ..
				'Terug levering Laag ' ..vandaagKwhtl.. ' kWh' .. '\n' ..
				 'Verbruik Hoog ' ..vandaagKwhvh.. ' kWh'.. '\n' ..
 				'Verbruik Laag ' ..vandaagKwhvl.. ' kWh'.. '\n' ..
 				'Totaal Opbrengst Zonnepanelen ' ..vandaagSolar.. ' kWh'.. '\n' ..
 				'Totaal Verbruik Elektra vandaag ' ..vandaagKwh.. ' kWh'.. '\n' ..
  dz.notify(subject, message, dz.PRIORITY_MEDIUM, dz.SOUND_PERSISTENT, nil, dz.NSS_TELEGRAM)
Larsoss
Re: Merge
Post by Larsoss »
Thank you. It's working perfect.
