2020-05-14 15:59:40.964 Error: dzVents: Error: (3.0.4) test timer script: /home/pi/domoticz/dzVents/runtime/Utils.lua:87: attempt to perform arithmetic on a nil value (local 'hours')
SwitchOff is executed and program stops execution right after.
The same 'at' conditions in
at() does not use the relative timer rules. You can only use absolute times / days.
From the wiki..
.at(hh:mm[:ss][ on [ ddd|dddd ] ): Function.3.0.1 Activates the command at a certain time [ on a certain day]
device.switchOn().at('09:00') -- earliest moment it will be 09:00 hr.
device.switchOn().at('08:53:30 on fri') -- earliest moment it will be Friday at 08:53:30
device.switchOn().at('08:53:30 on sat, sun') -- earliest moment it will be Saturday or Sunday at 08:53:30 (whatever comes first)
