repeatAfterSec strange behaviour  [Solved]
acaonweb
Post by acaonweb »
HI,
I'm trying to create a script for flashing a bulb 3 times from white to red, when a vibration is triggered
My script is like this
		devices = {
			'Vibrazione1'
	execute = function(dz, device)
	        -- send notification
		dz.notify('Camera',"Cassetto in movimento",dz.PRIORITY_NORMAL,0,'iPhone6S',dz.NSS_PUSHOVER)
		dz.devices("Luce Sottotetto Cassettiera").setColor(255,0,0).repeatAfterSec(2,3)
		dz.devices("Luce Sottotetto Cassettiera").setColor(255,255,255).afterSec(1).repeatAfterSec(2,3)
The bulb turns to red,
But i get this error (don't refer to row number, i've deleted some parts :) )
2020-04-08 08:15:34.678 Error: dzVents: Error: (3.0.1) An error occurred when calling event handler dz_cassetto
2020-04-08 08:15:34.678 Error: dzVents: Error: (3.0.1) ...moticz/scripts/dzVents/generated_scripts/dz_cassetto.lua:12: attempt to call a nil value (field 'repeatAfterSec')
and the bulb never come back to white
It's a bug or i'm doing wrong?
Thanx in advance.
Fabrizio
Re: repeatAfterSec strange behaviour
acaonweb wrote: Wednesday 08 April 2020 8:26 I'm trying to create a script for flashing a bulb 3 times from white to red, when a vibration is triggered
the repeatAfterSec() is not available for setColor (see this table in the wiki )
acaonweb
Post by acaonweb »
waaren wrote: Wednesday 08 April 2020 9:27
ok, so how can achive my goal?
acaonweb wrote: Wednesday 08 April 2020 15:23 ok, so how can achive my goal?
You could try with something like
return
	on =
		devices =
			'Vibrazione1'
	logging =
		level = domoticz.LOG_DEBUG,
		marker = 'flashing',
	execute = function(dz, item)
		dz.log(item.name .. ', state = ' .. item.state, dz.LOG_DEBUG)
		if item.state == 'On' then
			luce = dz.devices("Luce Sottotetto Cassettiera")
			for flash = 0, 4, 2 do
				luce.setColor(255,0,0).afterSec(flash)
				luce.setColor(255,255,255).afterSec(flash + 1)
acaonweb
Re: repeatAfterSec strange behaviour  [Solved]
Post by acaonweb »
Fast and simple. Thanks to everyone
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Hi Waaren,
I'm trying to figure out what happens in this script.
It look like this will result in a afterSec(0, 4, 2) and for the second line in afterSec(1, 4, 3). But I do not know how this is working then. Could you or someone explain this to me?
I'd like to use this part to make a light flash red/blue. :)
AllesVanZelf wrote: Thursday 09 July 2020 14:57 I'm trying to figure out what happens in this script.
       print (flash)
means a start value of 0, an end value of 4 with a step size of 2
this code will print
0
2
4
AllesVanZelf
Yes, very good. I can use that! Thanks Waaren.
