_G.moduleLabel return nil value  [Solved]
hestia
Domoticz version: 2022.1
Post by hestia »
I have installed the last stable and I have errors due to _G.moduleLabel is nill
I've upgraded to the last beta with same issue
Version: 2020.1 (build 11836)
Build Hash: 7e0c5045a
Compile Date: 2020-03-25 17:53:32
dzVents Version: 3.0.1
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
it was ok with:
Version: 4.11605
Build Hash: 7de1f368f
Compile Date: 2020-01-08 23:12:15
dzVents Version: 2.5.5
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
Re: _G.moduleLabel return nil value
hestia wrote: Wednesday 01 April 2020 21:44 I have installed the last stable and I have errors due to _G.moduleLabel is nil
Thx for reporting. Don't know yet why this does no longer exist. Will try to find out and correct if possible. Until fixed you will have to set a marker
in
logging = { level = domoticz.LOG_DEBUG, marker = ' scriptName' },
hestia
Post by hestia »
Thanks for replying and having agreed so fast ;-)
Until fixed you will have to set a marker in
I could just do this
 _G.logMarker =  ' scriptName'
because _G.logMarker is working, but _G.moduleLabel not!
Re: _G.moduleLabel return nil value  [Solved]
hestia wrote: Wednesday 01 April 2020 22:04 Thanks for replying and having agreed so fast ;-)
(kind of) Fixed in next Beta.
moduleLabel is available but no longer in global _G table but in the domoticz object.
so if you have
execute = ( domoticz, item)
You can get moduleLabel as domoticz.moduleLabel
and if you have
execute = ( dz, item)
You can get moduleLabel as dz.moduleLabel
hestia
Post by hestia »
Thanks waaren
I'm not familiar to compile domoticz, so I'm going to wait for a version to download.
Meanwhile I added the line in the lua EventHelpers.lua and it works.
I'll have to change my scripts but it is a small change ;-)
