Trigger dzvents script trough api.  [Solved]
OedzesG
Post by OedzesG »
Hallo,
at the moment im using Tautulli to monitor plex activitys, Tautulli can send an json call to domoticz based on playbacks.
i tested this with updating some uservariables and this works great..
But is there a way to trigger a dz.vents script by using a json call?
try to do something like this, but its not working..
		devices = {
			'test'
	execute = function(domoticz, mySwitch)
			domoticz.emitEvent('my_switch').switchOn()
and then i try to trigger it with:
http://192.168.1.11:8080/json.htm?type=command&param=customevent&event=my_switch
Re: Trigger dzvents script trough api.
OedzesG wrote: Wednesday 04 March 2020 11:38 But is there a way to trigger a dz.vents script by using a json call?
Syntax is a bit different
-- CustomEvent trigger. !! Only  available in dzVents >= V3.0.0 !!
-- Triggered by JSON call <domoticz IP: domoticz port>/json.htm?type=command&param=customevent&event=myCustomEvent&data=myData
return
    on =
        customEvents =
            'myCustomEvent',
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = 'CustomEvent',
    execute = function(dz, item)
        dz.log(item.trigger .. ' triggered this script ',dz.LOG_DEBUG)
        dz.log('payload is: '.. item.data,dz.LOG_DEBUG)
OedzesG
Re: Trigger dzvents script trough api.  [Solved]
Post by OedzesG »
Thnx waaren! did the job!
