Switching on severall devices  [Solved]
janpeetoom
Post by janpeetoom »
Hello.
I have a small problem. I'm trying to write a script to switch on 3 lights outside for 1 minute if a detector "bewegings melder' detectes movement. Thescript only needs to be activated 10 minutes after sunset. Also one of the lights does'nt have to be switched on if a switch "sauna bezoek' is switched on. I am struggeling to write this script. Is there anyone who can help me?
This is what I have so far. I know it's full of erros :)
      timer = {'10 minutes after sunset'},
      devices = { 'bewegings melder' }
      if (item.isTimer) then
         -- the timer was triggered
         domoticz.devices('Fitting').switchOff()
      elseif (item.isDevice and item.active) then
         -- it must be the detector
         domoticz.devices('Fitting').switchOn().forMin(1)
         domoticz.devices('Licht steeg').switchOn().forMin(1)
         domoticz.devices('Licht blokhut').switchOn().forMin(1)
Re: Switching on severall devices
janpeetoom wrote: Saturday 29 February 2020 13:18 I have a small problem. I'm trying to write a script to switch on 3 lights outside for 1 minute if a detector "bewegings melder' detectes movement.
could be something like
return
    on =
        devices =
        	['bewegings melder'] = { 'between 10 minutes after sunset and sunrise' },
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = 'myLight',
    execute = function(dz, item)
        if item.active then
            local fitting = dz.devices('Fitting')
            local steeg = dz.devices('Licht steeg')
            local blokhut = dz.devices('Licht blokhut')
            local sauna = dz.devices('sauna bezoek')
            local function onFor(device, duration, exception)
                if exception then return end
                device.cancelQueuedCommands()
                device.switchOn()
                device.switchOff().afterSec(duration)
            onFor(fitting, 60, sauna.state == 'On') -- if sauna bezoek 'On' then exception will be true and onFor will return immediate without any action
            onFor(steeg, 60)
            onFor(blokhut, 60)
janpeetoom
Thanks Waaren for the quick reply.
I have copied your script into domoticz
Now I get this message:
2020-03-01 16:31:59.531 ...domoticz/scripts/dzVents/generated_scripts/Script #3.lua:5: unexpected symbol near '['
2020-03-01 16:32:00.423 Status: dzVents: Error (2.4.19): error loading module 'Script #3' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Script #3.lua':
Any idea?
boum
Domoticz version: 4.10717
Post by boum »
A pair of curly brackets is missing for the devices value:
    on =
        devices =  {
janpeetoom
Thanks for your responce. The following error occurs now: 2020-03-02 18:03:42.215 Status: dzVents: Error (2.4.19): error loading module 'Script #3' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Script #3.lua':
2020-03-02 18:03:42.215 ...domoticz/scripts/dzVents/generated_scripts/Script #3.lua:8: unexpected symbol near '='
If I remove the loggig part en proceed with the execute = function part the same erro occurs.
janpeetoom
Re: Switching on severall devices  [Solved]
Allready figured it out after some tweaking.
This is the final sctipt:
return
    on =
        devices =  {
    if item.active then
            device.switchOn()
        onFor(steeg, 60)
        onFor(blokhut, 60)
Thanks for all the help.
