Need help in diagnosing a script  [Solved]
darkdude
Domoticz version: Release
Post by darkdude »
I need some help in diagnosing a script.
In my setup when a pump is turned on, waterflow readings are being sent to Domoticz every second. They are fed to a waterflow sensor and a variable (as I could not get dzVents or Blockly to work with the sensor). I need a script to check the waterflow around 20 seconds after the pump was started. If it's too low, a safety switch should be triggered. My script looks like this:
	on = {	variables = {"pompa_zbiornika_przeplyw"},
	data = { count = { initial = 0 }
   execute = function(domoticz, _)
       local przeplyw = domoticz.variables("pompa_zbiornika_przeplyw").value
       local pompa = domoticz.devices("POMPA ZBIORNIKA").state
       if (pompa == "On")  then
           domoticz.data.count = domoticz.data.count + 1
       elseif (pompa ~= "On") then
           domoticz.data.count = 0
       if  (domoticz.data.count >= 20 ) then
           if (przeplyw >= 0 and przeplyw <= 5 and pompa == 'On' ) then
	      domoticz.devices("BLOKADA POMPY ZBIORNIKA").switchOn().checkFirst()
           elseif (przeplyw > 5 and przeplyw < 22 and  pompa == 'On' ) then
	      domoticz.devices("BRUDNY FILTR ZBIORNIKA").switchOn().checkFirst()
It doesn't report any errors, however it's never triggered. I get constant info on the log that the variable was updated, however the script does not run. Updating the waterflow variable manually also does not trigger the script.
Regards, darkdude
Re: Need help in diagnosing a script
darkdude wrote: Wednesday 26 February 2020 9:18 I need some help in diagnosing a script.
You made a small mistake misplacing one of the }
To prevent such easy made mistakes you could use an approach where you align all opening and closing ones at the same column.
return
    on =
        variables =
            "pompa_zbiornika_przeplyw",
    data =
        count =
            initial = 0,
     logging =
        level = domoticz.LOG_DEBUG,
        marker = 'waterflow',
   execute = function(domoticz)
       if pompa == "On"  then
darkdude
Re: Need help in diagnosing a script  [Solved]
Post by darkdude »
