Read JSON data and update level blind  [Solved]
djdevil
Domoticz version: 2021.1
Post by djdevil »
Hi everyone, I'm using a python script to issue commands and a bluethoot roller shutter engine.
The script by running this command:
curl -i http://192.168.1.29:5000/AM43BlindsAction/CheckStatus
gives me this output
HTTP/1.0 200 OK
Content-Type: text/html; charset=utf-8
Content-Length: 193
Server: Werkzeug/1.0.0 Python/3.7.3
Date: Sun, 16 Feb 2020 18:30:15 GMT
    "Tenda bagno": [
            "battery": 78,
            "light": 0,
            "macaddr": "02:A0:07:6A:94:8D",
            "position": 99
    "status": "OK"
is it possible to create a script that extrapolates the given "position" value and updates the idx every 5 minutes? thanks in advance for the help
djdevil
Re: Read JSON data and update level blind
Post by djdevil »
there is no one you can help me thanks :oops:
djdevil wrote: Monday 17 February 2020 13:14 there is no one you can help me thanks :oops:
Sure someone can. But what kind of idx should be updated every 5 minutes ? Is it a switch, or a text device a uservariable maybe ? Please do not expect forum member to read your mind :)
djdevil
Post by djdevil »
waaren wrote: Monday 17 February 2020 13:55
you are right, sorry! :oops:
the idx is Blinds Percentage Inverted
djdevil wrote: Monday 17 February 2020 14:30 you are right, sorry! :oops:
Could be something like
local scriptVar = 'blindPosition'
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = scriptVar,
    execute = function(dz, item)
        if item.isTimer then
            dz.openURL({
                url = 'http://192.168.1.29:5000/AM43BlindsAction/CheckStatus',
                callback = scriptVar,
            return
        if item.ok then
            local blind = dz.devices('Tenda bagno') -- Change to name of domoticz device
            local rt = item.json
            local position = rt['Tenda bagno'][1].position
            dz.log('Position of blind is ' .. position, dz.LOG_DEBUG
            blind.dimTo(position).silent()
           dz.log('There was a problem handling the request', dz.LOG_ERROR)
           dz.log(item, dz.LOG_ERROR)
djdevil
Post by djdevil »
Not work this is my degub log:
2020-02-17 18:18:00.681 Status: dzVents: Info: blindPosition: ------ Start internal script: Script #1:, trigger: every 1 minutes
2020-02-17 18:18:00.681 Status: dzVents: Debug: blindPosition: OpenURL: url = http://192.168.1.29:5000/AM43BlindsAction/CheckStatus
2020-02-17 18:18:00.681 Status: dzVents: Debug: blindPosition: OpenURL: method = GET
2020-02-17 18:18:00.681 Status: dzVents: Debug: blindPosition: OpenURL: post data = nil
2020-02-17 18:18:00.681 Status: dzVents: Debug: blindPosition: OpenURL: headers = nil
2020-02-17 18:18:00.681 Status: dzVents: Debug: blindPosition: OpenURL: callback = blindPosition
2020-02-17 18:18:00.681 Status: dzVents: Info: blindPosition: ------ Finished Script #1
2020-02-17 18:18:03.265 Status: dzVents: Info: blindPosition: ------ Start internal script: Script #1: HTTPResponse: "blindPosition"
2020-02-17 18:18:03.284 Status: dzVents: Debug: blindPosition: Processing device-adapter for Tenda Bagno: Switch device adapter
2020-02-17 18:18:03.284 Status: dzVents: Error (2.4.19): blindPosition: An error occured when calling event handler Script #1
2020-02-17 18:18:03.284 Status: dzVents: Error (2.4.19): blindPosition: ...domoticz/scripts/dzVents/generated_scripts/Script #1.lua:37: attempt to index local 'rt' (a nil value)
2020-02-17 18:18:03.284 Status: dzVents: Info: blindPosition: ------ Finished Script #1
Re: Read JSON data and update level blind  [Solved]
djdevil wrote: Monday 17 February 2020 18:18 Not work this is my debug log:
Probably the response of your Bluetooth does not tell domoticz it returns a json. Can you try this one ?
return
    on =
        timer =
            'every 5 minutes',
        httpResponses =
            scriptVar
    logging =
        marker = scriptVar,
            dz.openURL({
            return
        if item.ok then
            local rt = dz.utils.fromJSON(item.data)
            if rt == nil then
                return
djdevil
Post by djdevil »
:D it work
 2020-02-17 20:07:02.000 Status: dzVents: Info: blindPosition: ------ Start internal script: Script #1: HTTPResponse: "blindPosition"
2020-02-17 20:07:02.019 Status: dzVents: Debug: blindPosition: Processing device-adapter for Tenda Bagno: Switch device adapter
2020-02-17 20:07:02.024 Status: dzVents: Debug: blindPosition: Position of blind is 95
2020-02-17 20:07:02.024 Status: dzVents: Debug: blindPosition: Constructed timed-command: Set Level 95
2020-02-17 20:07:02.024 Status: dzVents: Debug: blindPosition: Constructed timed-command: Set Level 95 NOTRIGGER
2020-02-17 20:07:02.024 Status: dzVents: Info: blindPosition: ------ Finished Script #1
can the 95% position be reversed? actually it would be 5% on the switch
djdevil
Post by djdevil »
djdevil wrote: Monday 17 February 2020 20:09 :D it work
I solved it like this!
blind.dimTo(101-position).silent()
thanks waaren for the help you have given to me and that you give to the domoticz community every day ;)
