Switch a Mixed Group to on with toggle command  [Solved]
Harald777
Domoticz version: Latest
Post by Harald777 »
Hi there,
I am totally new with DzVents scripting so looking for a solution / tip for the following issue:
I have a Aqara dual rocker wall switch, named "Gang schakelaar' and I want to control the following lights / group with the the Aquara outputs B1, B2, B3 & B6.:
- Group "Woonkamer" (with 5 lights) toggle on B1 input - (single push lh switch)
- Light "Eettafel" toggle on B2 input - (single push rh switch)
- Light "Vloerlamp" toggle on B6 input - (dual push rh switch)
- Light ''Tuinverlichting" toggle on B3 input - (dual push lh switch)
Used the following code:
   on = { devices = { "Gang schakelaar" }           },
   execute = function(dz, switch )
      if switch.state == "B2" then
            dz.devices("Eettafellamp").toggleSwitch()
      elseif switch.state == "B6" then
            dz.devices("Vloerlamp").toggleSwitch()
      elseif switch.state == "B3" then
            dz.devices("Tuinverlichting").toggleSwitch()
      elseif switch.state == "B1" then
            dz.groups("Woonkamer").toggleGroup()
All is working fine as long as the group "Woonkamer" is in the state On or OFF.
As soon as this group in in the state "Mixed" the toggelGroup command is not working.
Is there a way to switch my "Woonkamer" group to on when it is in a mixed state?
Perhaps my approach on this is totally wrong, please let my know, any tips are much appreciated.
Greetings, Harald
Re: Switch a Mixed Group to on with toggle command
Harald777 wrote: Wednesday 11 December 2019 20:52 Is there a way to switch my "Woonkamer" group to on when it is in a mixed state?
Yes; method to use is
switchOn()
return
    on =
        devices = { 'Gang schakelaar' },
    logging = { level = domoticz.LOG_DEBUG }, -- switch to LOG_ERROR when working as expected
    execute = function(dz, item)
	    _G.logMarker =  _G.moduleLabel
        local Eettafellamp = dz.devices("Eettafellamp")
        local VloerLamp = dz.devices("Vloerlamp")
        local TuinVerlichting = dz.devices("Tuinverlichting")
        local Woonkamer = dz.groups("Woonkamer")
        if item.state == "B2" then
            Eettafellamp.toggleSwitch()
        elseif item.state == "B6" then
            Vloerlamp.toggleSwitch()
        elseif item.state == "B3" then
            Tuinverlichting.toggleSwitch()
        elseif item.state == "B1" then
            if Woonkamer.state ~= 'Mixed'then
                Woonkamer.toggleGroup()
                Woonkamer.switchOn()
Harald777
Re: Switch a Mixed Group to on with toggle command  [Solved]
Post by Harald777 »
waaren wrote: Wednesday 11 December 2019 21:38 Yes; method to use is switchOn()
Waaren, thanks again for you assistance, working realy great now.
I have a lot to learn about Lua and DzVentz scripting.
Using Domoticz for a couple of years and until know only used Blockly for scenarios.
But the possibilities with scripts are much more extensive but also more complicated and I have to spent a lot more time in learning the scripts basic.
For know this is working great, thanks.
Greetings, Harald
