I use info.scriptName default as a part of my logging.
Is it possible to use this property in the marker part of a script?
logging = { level = domoticz.LOG_DEBUG,
marker = info.scriptName (also tried domoticz.info.scriptName)
etc.
Use info.scriptName in marker [Solved]
pvklink
- Domoticz version: latest b
Jablotron connection, Ikea
- waaren
Re: Use info.scriptName in marker [Solved]
No. that info is not available in the logging = section.pvklink wrote: Sunday 27 October 2019 9:21 I use info.scriptName default as a part of my logging.
You could achieve what you want if you do something like below
return
on = { devices = { 'triggerG' }},
logging = { level = domoticz.LOG_DEBUG },
execute = function(dz, device)
_G.logMarker = _G.moduleLabel
-- rest of script
pvklink
Unbelie... that you know al this... always an alternative
And yes it works! very easy when using a template for all your scripts and always usable...
thanks again!
thanks again!
