I have a small question about the ifttt script.
It works wunderful within domoticz and IFTTT !
Last part is converting my node-red nora scripts to use ifttvar
I normally use this content to execute a device with ifttvar : [{"obj":"lantaarn","act":"On"}]
But this special node for google home uses id's.
Does this script also handles id's instead of names?
I tried:
[{"obj":"1002","act":"On"}]
[{"obj":1002,"act":"On"}] but they dont work...
am i doing something wrong, or does this script only work with devicename (dont get me wrong, i am VERY happy with this script, i used it 1000 times....
syntax of JSON in uservar:
{"obj":"IFvar","set":"TestString"},
{"obj":"IFswitch","act":"On","fS":10,"aS":10,"si":true},
{"obj":"IFSelector","lbl":"Level1"},
{"obj":"IFScene","act":"On"}]
or
{"obj":"message from ifttt","msg":["message to all"]},
max. number of chars = 200
every action request in the json should have obj/object and max. one of (act/action, lbl/label, msg/message, set or upd/update, ).
Other controls (aS/afterSec, fS/ forSec, rAS/repeatAfterSec, si/silent are optional.
if message/msg is the requested action the object field is used as subject and subtable [{}]
mandatory line.object message subject
mandatory line.message[1] message body
optional or nil line.message[2] message priority (-2=LOW, -1=MODERATE, 0=NORMAL, 1=HIGH, 2=EMERGENCY)
optional or nil line.message[3] message sound (string like 'pushover','bike','none')
optional or nil line.message[4] extra
optional or nil line.message[5] subsystem or table with subsystems
examples
[{"obj":"message from ifttt","msg":["message to all notification systems with default priority"]}]
[{"obj":"message from ifttt","msg":["message to pushover with high priority",1,null,null,"pushover"]}]
[{"obj":"message from ifttt","msg":["message to pushover and gcm with low priority",-2,null,null,["pushover","gcm"] ]}]
if OSCommand/os is the requested action, the object field is used program / scriptname. name must be full qualified e.g. "/home/pi/scripts/myScript.sh"
local iftttvar = "IFTTTvar"
return
on =
variables = { iftttvar },
logging =
level = domoticz.LOG_DEBUG,
marker = 'ifttt',
execute = function(dz, item)
local function makeLongKeys(str)
local shortNames = {
act="action", -- optional: Can be On, Off or OS/OScommand:
-- On; valid for switches and groups and scenes and scenes; Off; valid for switches and groups
aS="afterSec", -- optional:
fS="forSec", -- optional: Only valid for standard (On/Off) switches
lbl="label", -- optional: levelName or number for selector type switches
msg="message", -- Optional: obj must be set to subject
obj="object", -- Mandatory and must be unique in domoticz: name for device, scene, group or uservariable.
os="OSCommand", -- if os / OSCommand is the requested action, obj must be set to full qualified script /program.
rAS="repeatAfterSec", -- optional: Only valid for standard (On/Off) switches
set="set", -- Optional: update uservariable
si="silent", -- Optional: use "si":true in JSON
upd="update", -- Optional: Only valid for devices (set nValue, sValue)
for short, long in pairs(shortNames) do
str = str:gsub('%f[%a]' .. short .. '%f[%A]' ,long) -- this will only replace short with long if short is a whole word
return str
local function getBaseType(name)
for i, tuple in ipairs(_G.domoticzData) do
if tuple.name == name then
return tuple.baseType, tuple.id
local function makeTarget(baseType, name)
if baseType == 'device' then
return dz.devices(name)
elseif baseType == 'group' then
return dz.groups(name)
elseif baseType == 'scene' then
return dz.scenes(name)
elseif baseType == 'uservariable' then
return dz.variables(name)
local function doLabelVariant(line, target)
if line.afterSec and line.silent then
target.switchSelector(line.label).silent().afterSec(line.afterSec)
elseif line.afterSec then
target.switchSelector(line.label).afterSec(line.afterSec)
elseif line.silent then
local function doUpdateVariant(line, target)
target.update(line.update).silent().afterSec(line.afterSec)
target.update(line.update).afterSec(line.afterSec)
local function doSetVariant(line, target)
target.set(line.set).silent().afterSec(line.afterSec)
target.set(line.set).afterSec(line.afterSec)
local function doOnVariant(line, target)
if line.afterSec and line.forSec and line.silent then
target.switchOn().silent().afterSec(line.afterSec).forSec(line.forSec)
elseif line.afterSec and line.repeatAfterSec and line.silent then
target.switchOn().silent().afterSec(line.afterSec).repeatAfterSec(line.repeatAfterSec)
elseif line.afterSec and line.silent then
target.switchOn().afterSec(line.afterSec)
target.switchOn()
local function doOffVariant(line, target)
target.switchOff().silent().afterSec(line.afterSec).forSec(line.forSec)
target.switchOff().silent().afterSec(line.afterSec).repeatAfterSec(line.repeatAfterSec)
target.switchOff().afterSec(line.afterSec)
target.switchOff()
local function doStopVariant(line, target)
target.stop().silent().afterSec(line.afterSec)
target.stop().afterSec(line.afterSec)
target.stop()
local function doNotificationVariant(line)
dz.notify(line.object,line.message[1],line.message[2] or nil,line.message[3] or nil,line.message[4] or nil,line.message[5] or nil)
local function doOSVariant(osCommand)
os.execute('sudo ' .. osCommand .. ' &')
dz.utils.dumpTable(result)
local function doTasks(result)
for _, line in ipairs(result) do
if line.message then
elseif line.action == 'OSCommand' then
doOSVariant(line.object)
local baseType, idx = getBaseType(line.object)
target = makeTarget(baseType, line.object)
if not(target) then
dz.log('no device, scene, group or var found',dz.LOG_ERROR)
return
if line.action and line.action == 'Off' then -- for switch type devices and groups
elseif line.action and line.action == 'On' then -- for switch type devices, scenes and groups
elseif line.action and line.action == 'OSCommand' then
doOSVariant(line, target)
elseif line.action and line.action == 'Stop' then -- for type blinds
elseif line.label then -- for selector type devices
elseif line.set then -- for uservariables
elseif line.update then -- for devices to set nValu, sValue
-- main
local result = dz.utils.fromJSON(makeLongKeys(item.value))
doTasks(result)
