Removing a value from an array  [Solved]
Gerwazy
Domoticz version: 4.10717
Post by Gerwazy »
I going to create a script handling with lights downstairs. I created an array with devices and want to add or remove a device depending on its state.
As far I understood, to add or remove a value from an array I have to use LUA (?)
My script (especially 2nd line)
local lights = domoticz.devices().filter({ 'LedRelaxSides', 'LedRelaxMiddle', 'LightRelaxLibrary', 'LightRelaxWall'})
            local lights2 = domoticz.utils._.pull(lights, 'LedRelaxSides')
            lights2.forEach(function(light)
                    domoticz.log(" TEST " .. light.name)
            end)
But it shows 4 devices (all) and I expected only 3 (without LedRelaxSides)
What do I wrong?
Thank you in advance.
Last edited by Gerwazy on Saturday 07 September 2019 12:26, edited 3 times in total.
Re: Removing a value from an array  [Solved]
Gerwazy wrote: Saturday 07 September 2019 10:41 I going to create a script handling with lights downstairs. I created an array with devices and want to add or remove a device depending on its state.
What do I wrong?
The filter returns devices into the table lights and you try to remove a string (name).
If you change it to
            local lights2 = domoticz.utils._.pull(lights, domoticz.devices('LedRelaxSides'))
            end)
You will see the expected result.
Please note that using this method you will remove the device LedRelaxSides from both lights and lights2.
Gerwazy
Post by Gerwazy »
Corrected according to your advice and works as expected.
Thank you waaren!
lights.forEach(function(light)
end)
