question about error  [Solved]
mcmikev
Post by mcmikev »
I run the presence detection with unifi cloudkey script and that was running fine for long time.
Since a few git pulls ago I get errors in the log (and I get mails as well when an error occurs) so I get regular mails now.
The error is : dzVents: Error: (2.4.26) HTTP/1.1 response: 60 ==>> Peer certificate cannot be authenticated with given CA certificates
I know that the cert is not right official because It is self signed and only used internal. How can I stop this error from occuring for internal sites/certs ??
Re: question about error
mcmikev wrote: Tuesday 23 July 2019 7:56 The error is : dzVents: Error: (2.4.26) HTTP/1.1 response: 60 ==>> Peer certificate cannot be authenticated with given CA certificates
@mcmikev
Can you please share the script ?
What OS are you on ?
mcmikev
Post by mcmikev »
rpi3 with stretch
anonymized script
      timer = { 'every 5 minutes' },
      httpResponses = { 'loggedin' , 'data' }
        if (item.isTimer) then
            domoticz.openURL({
                url = 'https://192.168.x.x:8443/api/login',  --Change IP and Port to your Unifi Controller settings
                method = 'POST',
                postData = { ['password'] = 'xxxxxx' , ['username'] = 'xxxxxxx' }, --Change YourPassword en YourUsername to your password en username for Unifi Controller
                callback = 'loggedin'
        if (item.isHTTPResponse and item.ok) then
            if (item.trigger == 'loggedin') then
                domoticz.openURL({
                url = 'https://192.168.x.x:8443/api/s/default/stat/sta',  --Change IP and Port to your Unifi Controller settings
                method = 'GET',
                callback = 'data'
                -- iPhone,
                local Mac = {'d4:xx:xx:xx:xx:0a'}  --Change to mac addresses of devices you want to monitor
                local DzIndx = {95,536,694,695}  --Change to Domiticz Idx, the position in DxIndx has to be the same as the mac adress for that device in Mac (previous line)
                for i,y in ipairs(Mac)
                do
                    home = string.find( item.data , Mac[i])
                    if (home == nil) then
                        domoticz.devices(DzIndx[i]).switchOff().checkFirst()
                        domoticz.devices(DzIndx[i]).switchOn().checkFirst()
mcmikev wrote: Tuesday 23 July 2019 11:49 rpi3 with stretch ; anonymized script...
If you change line 15 from
to
        if (item.isHTTPResponse and ( item.ok or item.statusCode == 60 ) ) then
Your script will continue. The error message will still be shown in the log as domoticz / dzVents does see this as an error. If you don't want that you will have to change the runtime module <domoticz dir>/dzVents/runtime/HTTPResponse.lua and comment line 23
mcmikev
Post by mcmikev »
Hi Waaren,
In my file on line 23 there is this : self.ok = false
Is that the only line I need to comment out? Getting a bit frustrated with all the errors constantly LOL
mcmikev wrote:Hi Waaren,
Yes. Just try it and if it works, you will have to repeat that edit every domoticz update.
mcmikev
Post by mcmikev »
Remarked line 23 (placed - - before it, without the spaces between) but stil the same error.
Any other ideas?
mcmikev wrote: Tuesday 27 August 2019 18:56 Remarked line 23 (placed - - before it, without the spaces between) but stil the same error.
Any other ideas?
Yes, change line 20-23 (now)
    if self.statusCode >= 200 and self.statusCode <= 299 then
        self.ok = true
        self.ok = false
        if ( not testResponse ) and ( utils.log(self.protocol .. " response: " .. self.statusCode .. " ==>> " .. self.statusText ,utils.LOG_ERROR) ) then end
to
        self.ok = true
        self.ok = false
    	if self.statusCode ~= 60 then
mcmikev
Post by mcmikev »
just made the changes. Let's see
mcmikev
Re: question about error  [Solved]
Post by mcmikev »
Yes the error is gone with that edit ! thanks Waaren
