Error in dzVent.lua  [Solved]
nosehook
Post by nosehook »
I recently checked my error log and got the following error:
Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:96: attempt to index local 'fileStorage' (a boolean value)
I do not understand what the problem is or how to solve it.
Is there anyone who can help me?
EDIT: Solved, again global variables files... is there a solution for this?
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
Re: Error in dzVent.lua
nosehook wrote: Thursday 29 August 2019 14:55 I recently checked my error log and got the following error:
good to hear that it is already fixed. dzVents hands over the writing to the file to the OS. If the OS hits a problem when writing this file it's not reported back to dzVents. If this happens quite frequent it might point to a problem in your file-system / SD card
I will investigate if I can make the error message more descriptive.
