Modify DZ Vents  [Solved]
alarm_guy1
Modify DZ Vents
Post by alarm_guy1 »
Hi Guys,
I have for me an excellent DZ Vents Script created for me, it runs nearly every light in the house, however I could do with some assistance to tweak it a bit.
I'm going to add a door sensor to my bathroom door and would like to have it set like so:
if detector picks you up and the door remains open continue as normal
if the door is closed regardless of the detector state, lights to come on indefinately until door is opened but @20%
and after 23:30 just come on @1% as it is now
Many Thanks
alarm_guy1
Re: Modify DZ Vents
Forgot to attach code
return  {
            on          =   {
								devices           =		{
															"Bathroom MD Burglar",
            logging     =   {
                                level           =   domoticz.LOG_DEBUG,
                                marker          =   "Bathroom Motion"
    execute = function(dz, item)
        local function logWrite(str,level)
            dz.log(str,level or dz.LOG_DEBUG)
       -- local Lux = dz.devices("Kitchen MD Lux").lux
                local LuxDevice = dz.devices(177)                 -- <<<--- replace xxx by IDX of your Lux device
                local Lux = LuxDevice.lux
        -- local Lights = dz.devices("Bathroom Dimmer Level")
                local Lights = dz.devices(68)                       -- <<<--- replace xxx by IDX of your Bathroom lights
        logWrite(LuxDevice.name .. " ==>> Lux:   " .. Lux )
        logWrite(Lights.name ..    " ==>> State: " .. Lights.state)
        logWrite(item.name ..      " ==>> State: " .. item.state)
        if Lux < 1020 and item.state == "On" then
            Lights.cancelQueuedCommands()
			if dz.time.matchesRule("at 23:30-06:00") then
				Lights.dimTo(01)
				Lights.dimTo(90)
        elseif item.state == "Off" and Lights.state == "On" then
            Lights.switchOff().afterSec(300)
Cheers
Re: Modify DZ Vents
alarm_guy1 wrote: Saturday 20 July 2019 1:52 I'm going to add a door sensor to my bathroom door and would like to have it set like so:
If my interpretation of your requirements is correct it could look like
local bathroomSensor =  "Bathroom MD Burglar"
local bathroomDoor = "Bathroom door"
return
    on  =
        devices =
            bathroomSensor,
            bathroomDoor,
        timer =
            "every 5 minutes between 23:30 and 06:00",
    logging =
        local door = dz.devices(bathroomDoor)
        local sensor = dz.devices(bathroomSensor)
        logWrite(door.name .. " ==>> State: " .. door.state)
        logWrite(sensor.name .. " ==>> State: " .. sensor.state)
        local function timeConditionalDimmer(wake, sleep)
            if not wake then wake = 90 end
            if not sleep then sleep = 1 end
                Lights.dimTo(sleep)
                Lights.dimTo(wake)
        if item.isTimer then
            if ( door.state == "Closed" ) and ( door.lastUpdate.secondsAgo > 300 ) and ( sensor.lastUpdate.secondsAgo > 300 ) then
                timeConditionalDimmer()
        elseif Lux < 1020 and sensor.state == "On" then
        elseif door.state == "Closed" then
            timeConditionalDimmer(20)
        elseif sensor.state == "Off" and Lights.state == "On" and door.state == "Open" then
alarm_guy1
Re: Modify DZ Vents  [Solved]
Cool cheers.
Im just in the process of adding the contact to my alarm system then I will implement this code.
It wont be for a week or so as I never expected such a swift response.
Many many thanks.
I will let you know how it goes
cheers
