How to dim a light  [Solved]
Varazir
How to dim a light
Post by Varazir »
I created this test script to dim a light bulb, but it loops to quick.
IKEA Switch Brightness Down is a selector switch device so it has 4 states, Off, Click, Hold, Release
		devices = {
			'IKEA Switch Brightness Down'
		local dimDevice = domoticz.devices(73)
		local dimLevel = 100
    	if ( device.state == "Hold" )
    	    then
    	        repeat
    	            dimLevel = dimLevel - 5
    		        domoticz.log('Device ' .. dimLevel .. ' %', domoticz.LOG_INFO)
    		        dimDevice.dimTo(dimLevel)
    		    until ( device.state == "Release" or dimLevel < 5 )
    	if ( device.state == "Release" )
    	    then
    	        if (dimLevel == 0 )
    	            then
    	                dimDevice.switchOff()
    	        domoticz.log('Device ' .. device.name .. ' Release', domoticz.LOG_INFO)
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
poudenes
Domoticz version: 3.8993
Re: How to dim a light
Post by poudenes »
You can't use this line?:
domoticz.devices(73).dimTo(50)
Will dim device 73 to 50%
		devices = {
    	if ( device.state == "Hold" ) then
    	     	 domoticz.devices(73).dimTo(5)
    	elseif ( device.state == "Release" ) then
    	     	 domoticz.devices(73).switchOff()
Varazir wrote: Saturday 29 June 2019 10:57 I created this test script to dim a light bulb, but it loops to quick.
As dzVents does not change the devices by itself but hands over that action to domoticz after the script has finished you cannot use the new state of a device inside a dzVents script that changed that state. The state simply had not changed yet. Same is true for classic domoticz Lua and Blockly
Varazir
Post by Varazir »
waaren wrote: Saturday 29 June 2019 11:35
Okay, I have goten this far now and the diming works but I cant get it to stop
	    on =        {
		            devices          = { 'IKEA Switch Brightness Down' },
        logging =   {
                    level            =  domoticz.LOG_DEBUG,
                    marker           =  "IKEADown"
        data    =   {
                    buttonState      = { initial               },
    function sleep(s)
        local ntime = os.clock() + s
        repeat until os.clock() > ntime
    	    then
    	        repeat
    		        domoticz.log('Hold Button State ' .. domoticz.data.buttonState .. ' ', domoticz.LOG_INFO)
    		        sleep(1)
    		    until ( domoticz.data.buttonState == "Release" or dimLevel < 5 )
    	    then
    	        domoticz.data.buttonState = "Release"
    	        if (dimLevel == 0 )
    	            then
    	        domoticz.log('Release Button State ' .. domoticz.data.buttonState .. ' ', domoticz.LOG_INFO)
Re: How to dim a light  [Solved]
Varazir wrote: Sunday 30 June 2019 11:17 Okay, I have goten this far now and the diming works but I cant get it to stop
Please have a look at this.
return
    on =
    logging =
        level = domoticz.LOG_INFO,
        marker = "IKEADown"
        local delay = 0
        if device.state == "Hold"  then
            repeat
                delay = delay + 0.15
                dimLevel = dimLevel - 1
                domoticz.log('Set ' .. dimDevice.name .. ' to dimLevel '.. dimLevel .. '%, after ' .. delay .. ' seconds', domoticz.LOG_INFO)
                dimDevice.dimTo(dimLevel).afterSec(delay)
            until dimLevel <= 0
        elseif device.state == "Release" then
            domoticz.log('Stop dimming of ' .. dimDevice.name, domoticz.LOG_INFO)
            dimDevice.cancelQueuedCommands()
            if dimDevice.level == 0 then
Varazir
Post by Varazir »
waaren wrote: Sunday 30 June 2019 13:17
return
    on =
    logging =
        marker = "IKEADown"
        local delay = 0
            repeat
            until dimLevel <= 0
Thanks, it worked.
Then to the next step to make it dynamic.
But that is another thread :)
Diplo95
Domoticz version: 2021.1
Post by Diplo95 »
I join the thread because I try to find a way to dim a light with my Xiaomi Round 1 button switch.
Just to be sure, this script dim the light once the button is released ?
Varazir : have you found a way to dim the light when pushing the switch ?
Domoticz v2021.1 on Raspberry Pi 3B+
Raspbian Buster
ConBee II + Xiaomi devices
Zwave
