Change local variable from other script  [Solved]
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi ALl,
I use several local variables in some dzVent Scripts. Is it possible to change those local variables from outside the script itself?
Cheers
Peter
Re: Change local variable from other script
poudenes wrote: Saturday 22 June 2019 22:32 I use several local variables in some dzVent Scripts. Is it possible to change those local variables from outside the script itself?
No.
dzVents has global_data.lua to handles these kind of requirements. You could also store your values in a domoticz uservariable or in various fields in devices. (description field in most devices, text field in text-device, etc..)
poudenes
Re: Change local variable from other script  [Solved]
Post by poudenes »
Yes, I used it before in uservariable. Now put those in the scripts itself. Easier to handle. (ok till now because of this question)
I will take a look to add them in global_data.
Thanks for aswering :)
poudenes
Post by poudenes »
Solved:
Added this in global_data:
    data = {
        LuxEvening    = { initial = 0 },
        LuxMorning    = { initial = 0 },
        HomePeter     = { initial = 0 },
        HomeKay       = { initial = 0 },
        KodiPlayVar   = { initial = 0 },
        KodiStopVar   = { initial = 0 }
And then I can access the data in script with:
if (domoticz.globalData.KodiPlayVar == 0) then
     domoticz.globalData.KodiPlayVar = 1
Now I can read the variables from other scripts :D
