Ok, as nobody was able to help me on this, I have expiremented myself and in the end got myself a working program. As others may have the same issues, I add my script code here
local setdelay = 10
-- ADD DEVICES JUST ABOVE THE PROGRAM EXECUTION WITH return {
-- NO MORE CONFIGURING UNTIL THAT BLOCK OF CODE
local function addnewdevicelink (devicearray, virtual, physical, action, groupname)
local new = {}
if type(physical) == "table" then
for k, v in pairs(physical) do
addnewdevicelink(devicearray,virtual,v,action,groupname)
-- First set the name to device "name", even when empty (only for a new device)
new["name"]=groupname
local found=false
for k, v in pairs(devicearray) do
if k==virtual then
found=true
if not(found) then
devicearray[virtual]=new
-- now add device to the list (should always exist now)
local new = {}
new[physical]=action
local found=false
if k==virtual then
v[physical]=action
found=true
local function createdevicelist (linklist)
local returnarray = {}
for virt, val in pairs(linklist) do
if type(val) == "table" then
for real, action in pairs(val) do
if real ~= "name" then -- ignoring the 'name' device
local found = false
for icount=1,#returnarray do
if returnarray[icount]==real then
found = true
if not(found) then
table.insert(returnarray,real)
return returnarray
local function returnmatch(linklist,foundid) -- only the first virtual device will be returned
local found = false
if real == foundid then
if not(found) then
returnarray[virt] = action
found = true
return returnarray
local function returnname(linklist,virtid) -- only the first virtual device will be returned
local foundname = ""
local found = false
if virt==virtid then
if real == "name" then
if not(found) then
foundname = action
found = true
return foundname
function vertoon (a)
local retstring = ""
if type(a) == "table" then
for k, v in pairs(a) do
if type(v) == "table" then
retstring = retstring .. " " .. k .. " = { " .. vertoon(v) .. "},"
retstring = retstring .. " " .. k .. " = " .. v .. ","
retstring = retstring .. a .. ","
return retstring
local workarray = {}
-- ADD DEVICES HERE
addnewdevicelink(workarray,VDI_winkellicht,DID_winkellicht,ACT_followvirtual+ACT_notify,"Winkellicht")
addnewdevicelink(workarray,VDI_etalage,DID_etalage,ACT_onlyretryoff+ACT_notify,"Etalage")
addnewdevicelink(workarray,VDI_eetkamerlicht,{DID_eetkamerlicht, DID_eetkamergroot},ACT_donothing,"Eetkamer")
-- FINISH CONFIGURING HERE
devices = createdevicelist(workarray),
execute = function( dz, trig, info )
for key, value in pairs(returnmatch(workarray,trig.id)) do
if key > 0 then
if dz.devices(key).active ~= trig.active then
if value >= 10 then
value = value - 10
dz.helpers.sendTelegram(domoticz, TEL_sysalarmgroup, 'Value mismatch ' .. returnname(workarray,key) .. ' between ' .. key .. ' and ' .. trig.id)
if value == ACT_followvirtual then
dz.log('Need to Reset ' .. trig.id .. ', ' .. returnname(workarray,key),dz.LOG_FORCE)
if dz.devices(key).active then trig.switchOn().afterSec(setdelay)
else trig.switchOff().afterSec(setdelay)
if value == ACT_onlyretryoff then
if not(dz.devices(key).active) then
if value == ACT_onlyretryon then
dz.log('device ' .. trig.id .. ' not found in matchlist (' .. key .. "," .. value .. ")", dz.LOG_FORCE)
a) Sorry that my devices are in Dutch. I hope you have a grasp of things they do anyway (winkellicht=shoplight,eetkamer=diningroom,etalage=shopwindow)
b) I have set up global_data to have all the devices as variable names. When a device fails and needs to be replaced by another, I just have to change the device numbers there and all my other scripts just keep on functioning without any alteration.
- VDI = Virtual Device ID's
- DID = Device ID's of real devices {I am switching over from letting buttons and scripts change the status of the real device, but must change a virtual device that in turn switches one or multiple devices}
- ACT = Actions on what to do when there is a mismatch. I have defined:
- ACT_donothing = 0
ACT_followvirtual = 1
ACT_onlyretryoff = 2
ACT_onlyretryon = 3
ACT_notify = 10 -- this is a + action (e.g. ACT_followvirtual+ACT_notify)
c) Notification to my mobile device is done via a Telegram messaging function in my global_data
d) As any aftermin etc are executed by the virtual device, I do not need to take any of that info with me to the real devices
e) Make sure your physical switches are set to poling, otherwise they will never notify you that they have not executed the switch-command
f) I put a delay option (here set to 10 seconds) to prevent lights switching too fast, especially when a loop failure occurs. But this might be set to zero.
g) Easy ways to test this is to switch a powerplug by the button on it, or to change the state of the physical device in Domoticz, without changing the virtual value first.
h) Make sure your dashboard or dashticz do not show physical switches anymore, but just the virtual switches
i) I just finished programming it, but have only limitly tested it. So if you use it, use it as is and be aware, problems my pop up at any time. (you need to tweek it to your needs anyway)
