ELSEIF thermostat not triggering  [Solved]
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
Hello
I have an Evohome zone and some Z-Wave thermostats. This kind of works ok, but only the first IF, not the second. What I'm doing wrong?
Basically I can override the temperature from either the Evohome or the Z-wave virtual thermostat. When I override from Evohome it works, but when I override from the virtual thermostant, only the Evohome part triggers.
Heating override
	on = { devices = { 'Downstairs', 'Downstairs Thermostat'} },    -- EvoHome trigger or Virtual Thermostat
	execute = function(domoticz, Thermostat)
	   local DownEV = Thermostat.setPoint -- Evohome zone Thermostat
	   local oldTemp = domoticz.variables('recordTempDown').value -- user variable to record last set temperature
	   local DownTRV = Thermostat.setPoint -- setpoint of Virtual thermostant
	   if DownEV ~= oldTemp and domoticz.variables('updateBusy').value == 0 then
	            domoticz.variables('updateBusy').set(1) -- I'm busy
                domoticz.devices('Downstairs Thermostat').updateSetPoint(DownEV)
                domoticz.variables('recordTempDown').set(DownEV)
                print ("***************** Virtual Thermostat Down UPDATED!! to: " ..DownEV.." ********************")
                domoticz.variables('updateBusy').set(0) -- Not busy anymmore
        elseif
                DownTRV ~= oldTemp and domoticz.variables('updateBusy').value == 0 then
                domoticz.variables('updateBusy').set(1) -- Set to busy
                local myZone = domoticz.devices('Downstairs') -- Evohome zone
                local untilDateTime = os.date("!%Y-%m-%dT%TZ",os.time()+7200)  -- current time + 2 hours
                myZone.updateSetPoint(DownTRV,"TemporaryOverride",untilDateTime)
		        domoticz.variables('recordTempDown').set(DownTRV)
		        print ("************ SETPOINT Evohome zone updated " .. myZone.name .. " to: " .. DownTRV .. " , until: " .. untilDateTime .. " *******")
                domoticz.variables('updateBusy').set(0) -- Not busy anymore
11101101 - www.machinon.com
Re: ELSEIF thermostat not triggering
EdddieN wrote: Sunday 14 October 2018 18:30 I have an Evohome zone and some Z-Wave thermostats. This kind of works ok, but only the first IF, not the second. What I'm doing wrong?
I think you got your logic wrong here.
The script is triggered by either the evoHome or the virtual sensor and you evaluate the setpoint of whichever triggered the script. Lua doe not know from which sensor you are getting it because you don't give that information. Result is that either the first if evaluates to true and that block will be executed so no evaluation of the 2nd (else) if will take place. Or the first if evaluates to false and because they are effectively looking at the same the 2nd (else)if is also false.
Also your busy variable is not of any use here. The domoticz event system is single threaded meaning that only one script can be executed at the same time so no chance of interference from another sensor. The 2nd script just have to wait until the 1st finished.
If have not tested the script but can you give it a try ?
Heating override
local EvoHome           =  'Downstairs'
local virtualThermostat = 'Downstairs Thermostat'
    on = { devices = { EvoHome, virtualThermostat }},    -- EvoHome trigger or Virtual Thermostat
       logging =   {   level   =   domoticz.LOG_DEBUG,
                        marker  =   "Heating override" },
       local downThermostat = Thermostat.setPoint                       -- Evohome or Virtual Thermostat.setPoint
       local trigger        = Thermostat.name
       if DownEV ~= oldTemp and Thermostat.trigger ==  virtualThermostat then
                -- domoticz.variables('updateBusy').set(1)                             -- I'm busy   This does not make sense. The update will only take place after the script has finished
        -- And there can only be one script active at the same time
                domoticz.devices(virtualThermostat).updateSetPoint(downThermostat)
                domoticz.variables('recordTempDown').set(downThermostat)
                print ("***************** Virtual Thermostat Down UPDATED!! to: " .. downThermostat .." ********************")
                -- domoticz.variables('updateBusy').set(0) -- Not busy anymmore This does not make sense. The update will only take place after the script has finished
        elseif
                downThermostat ~= oldTemp and Thermostat.trigger == EvoHome then
                -- domoticz.variables('updateBusy').set(1) -- Set to busy This does not make sense. The update will only take place after the script has finished
                myZone.updateSetPoint(downThermostat,"TemporaryOverride",untilDateTime)
                print ("************ SETPOINT Evohome zone updated " .. myZone.name .. " to: " .. downThermostat .. " , until: " .. untilDateTime .. " *******")
                -- domoticz.variables('updateBusy').set(0) -- Not busy anymore This does not make sense. The update will only take place after the script has finished
EdddieN
Post by EdddieN »
Ok I get what you are doing now.
One thing missing is reading the value of the thermostat. How do you read the value of Evohome and virtualThermostate setpoint?
I try this but gives me a invalid parsing nil error:
Heating override
       local DownEV = Evohome.Thermostat.setPoint
       local downThermostat = virtualThermostat.Thermostat.setPoint
        elseif
EdddieN wrote: Sunday 14 October 2018 19:48 Ok I get what you are doing now.
This line reads the setPoint from the device that triggered the script.
Can you show the relevant loglines ?
EdddieN
Post by EdddieN »
waaren wrote: Sunday 14 October 2018 20:14
I need to read the setpoint of both, the ortherwise there's no way to compare the old value. The log is fine, it does not return errors. What happens is that the temperature does not transfer across neither the recordTempDown
The problem is here:
        elseif
DownEV and downThermostat have not been declared?
EdddieN
Post by EdddieN »
Ok, I think I narrowed it down to this part of the code that is not triggering:
I have put debug info and I can see that trigger = Downstairs Thermostat but when comparing to the virtualThermostat = 'Downstairs Thermostat' it sees them as not equal. Any idea why?
EdddieN
Re: ELSEIF thermostat not triggering  [Solved]
Post by EdddieN »
Finally, it works by replacing Thermostat.trigger with just trigger
Heating override
      -- print ("oldtemp " .. oldTemp)
      -- print ("Trigger " .. trigger)
      -- print ("Setpoint " .. downThermostat)
       if downThermostat ~= oldTemp and trigger ==  EvoHome then
        elseif
                downThermostat ~= oldTemp and trigger == virtualThermostat then
Thank you!
EdddieN
Post by EdddieN »
One final thing, I hope there's a solution for this.
My setup is as follows: I have the Evohome interface and then a wall mounted tablet with Imperihome. The thermostat in Imperihome changes by 0.5*C each touch so if I'm at 15 and I want to increase to 20*C, Imperihome sends 10 messages to Domoticz.
Then Domoticz as a good tasker starts to increase to 15.5 but before is finished it gets a new one and starts to get in a very long infinite loop of changes with the temperature UP and DOWN. I actually think that part of the culpit is Evohome being a bit slow to respond.
Is there any way to "buffer" or wait for the last command within the last 5 seconds to execute?
