switchOn not available for ELRO AB400?  [Solved]
Haringstad
Post by Haringstad »
Hello Folks,
Getting:
2017-07-18 20:41:00.241  dzVents: Info:  ------ Start internal script: Start Workday:, trigger: at 20:41 on mon,tue,wed,thu,fri
2017-07-18 20:41:00.278  Error: dzVents: Error: Method switchOn is not available for device "Bedroom Right Side" (deviceType=Lighting 1, deviceSubTyp
e=ELRO AB400). If you believe this is not correct, please report.
2017-07-18 20:41:00.279  Error: dzVents: Error: An error occured when calling event handler Start Workday
2017-07-18 20:41:00.279  Error: dzVents: Error: ...ticz/scripts/dzVents/generated_scripts/Start Workday.lua:29: attempt to index a nil value
2017-07-18 20:41:00.279  dzVents: Info:  ------ Finished Start Workday
-- Sunrise, turn off all kinds of lights
	active = true, -- set to false to disable this script
		timer = {
		    'at 20:41 on mon,tue,wed,thu,fri'
	execute = function(domoticz)
		local bedroom_left = domoticz.devices('Bedroom Left Side')
		local bedroom_right = domoticz.devices('Bedroom Right Side')
		local bedroom_blue_lamp = domoticz.devices('Bedroom Blue Lamp')
		local tall_lamp = domoticz.devices('Staande Lamp')
		local mirror_leds = domoticz.devices('Spiegel Leds')
		local livingroom = domoticz.devices('Huiskamer')
		if (not bedroom_left.bState) then
            local RANDOM_DELAY_MINS = 15
            bedroom_left.switchOn().withinMin(RANDOM_DELAY_MINS)
            domoticz.notify('Hey!', 'Kitchen Left Light switched on!', domoticz.PRIORITY_NORMAL)
		if (not bedroom_right.bState) then
            bedroom_right.switchOn().withinMin(RANDOM_DELAY_MINS)
		if (not bedroom_blue_lamp.bState) then
            bedroom_blue_lamp.switchOn().withinMin(RANDOM_DELAY_MINS)
		if (not tall_lamp.bState) then
            tall_lamp.switchOn().withinMin(RANDOM_DELAY_MINS)
        if (not mirror_leds.bState) then
            mirror_leds.switchOn().withinMin(RANDOM_DELAY_MINS)
In the regular LUA scripts, this switch functions Superb???
Regards, Jacco
dannybloe
Re: switchOn not available for ELRO AB400?  [Solved]
Post by dannybloe »
Yes, I noticed this. 2.1.1 should detect your switch properly. If you dare you can patch it yourself and try it out. Locate the file switch_device.lua in /path/to/domoticz/scripts/dzVents/runtime/adapters and change it to:
local TimedCommand = require('TimedCommand')
	baseType = 'device',
	name = 'Switch device adapter',
	matches = function (device, adapterManager)
		local res = (
			device.deviceType == 'Light/Switch' or
			device.deviceType == 'Lighting 1' or
			device.deviceType == 'Lighting 2' or
			device.deviceType == 'Lighting 3' or
			device.deviceType == 'Lighting 4' or
			device.deviceType == 'Lighting 5' or
			device.deviceType == 'Lighting 6' or
			device.deviceType == 'Lighting Limitless/Applamp' or
			device.deviceType == 'Fan' or
			device.deviceType == 'Curtain' or
			device.deviceType == 'Blinds' or
			device.deviceType == 'RFY' or
			device.deviceType == 'Chime' or
			device.deviceType == 'Thermostat 2' or
			device.deviceType == 'Thermostat 3' or
			device.deviceType == 'Thermostat 4' or
			device.deviceType == 'Remote & IR' or
			device.deviceType == 'Home Confort' or -- typo should be there
			(device.deviceType == 'Radiator 1' and device.deviceSubType == 'Smartwares Mode') or
			(device.deviceType == 'Value' and device.deviceSubType == 'Rego 6XX')
		if (not res) then
			adapterManager.addDummyMethod(device, 'switchOn')
			adapterManager.addDummyMethod(device, 'switchOff')
			adapterManager.addDummyMethod(device, 'close')
			adapterManager.addDummyMethod(device, 'open')
			adapterManager.addDummyMethod(device, 'stop')
			adapterManager.addDummyMethod(device, 'dimTo')
			adapterManager.addDummyMethod(device, 'switchSelector')
			adapterManager.addDummyMethod(device, 'toggleSwitch')
		return res
	end,
	process = function (device, data, domoticz, utils, adapterManager)
		-- from data: levelName, levelOffHidden, levelActions, maxDimLevel
		if (data.lastLevel ~= nil) then
			-- dimmers that are switched off have a last level
			device.lastLevel = data.lastLevel
		if (device.level == nil and data.data._nValue ~= nil) then
			-- rgb devices get their level in _nValue
			device.level = data.data._nValue
		function device.toggleSwitch()
			local current, inv
			if (device.state ~= nil) then
				current = adapterManager.states[string.lower(device.state)]
				if (current ~= nil) then
					inv = current.inv
					if (inv ~= nil) then
						return TimedCommand(domoticz, device.name, inv)
			return nil
		function device.switchOn()
			return TimedCommand(domoticz, device.name, 'On')
		function device.switchOff()
			return TimedCommand(domoticz, device.name, 'Off')
		function device.close()
		function device.open()
		function device.stop() -- blinds
			return TimedCommand(domoticz, device.name, 'Stop')
		function device.dimTo(percentage)
			return TimedCommand(domoticz, device.name, 'Set Level ' .. tostring(percentage))
		function device.switchSelector(level)
			return TimedCommand(domoticz, device.name, 'Set Level ' .. tostring(level))
		if (device.switchType == 'Selector') then
			device.levelNames = device.levelNames and string.split(device.levelNames, '|') or {}
			device.level = tonumber(device.rawData[1])
			device.levelName = device.state
and trigger your script again.
Please let me know if this works for you.
Cheers,
Danny
Haringstad
@dannybloe
Works like a CHARM!!! THNX!
dannybloe
Post by dannybloe »
Cool. I'll commit the change then :) Thanks.
