check dead devices script error  [Solved]
gmccarthy
Post by gmccarthy »
I'm trying to get the check dead devices.lua example script working and running into issues.
Getting this error:
2016-11-14 18:00:00.686 LUA: =====================================================
2016-11-14 18:00:00.687 LUA: >>> Handler: check-dead-devices
2016-11-14 18:00:00.687 LUA: .....................................................
2016-11-14 18:00:00.688 LUA: An error occured when calling event handler check-dead-devices
2016-11-14 18:00:00.688 LUA: ...e/pi/domoticz/scripts/lua/scripts/check-dead-devices.lua:23: attempt to concatenate local 'message' (a nil value)
2016-11-14 18:00:00.688 LUA: .....................................................
2016-11-14 18:00:00.688 LUA: <<< Done
I'm using the example as it except for changing the device name:
local devicesToCheck = {
        { ['name'] = 'Garage Door', ['threshold'] = 30 }
gmccarthy
Re: check dead devices script error  [Solved]
Post by gmccarthy »
Fixed it by changing code to:
local message = ''
