I have Zon op Toon, but I can't see it under Toon in devices.
I do see the P1-meter (usage and return), but not the Zon op Toon-Kwh meter.
What do I need to do to see the generated power in Domoticz?
Toon Energy Readings on Domoticz
- Domoticz version: Stable
Re: Toon Energy Readings on Domoticz
My Toon device has arrived today. I have added the hardware in Domoticz, all seems to work very well.
I don`t see any KWh meter, i only have the gas meter. Is this option not available anymore?
2017-01-02 19:44:31.423 ToonThermostat: Worker started...
2017-01-02 19:45:08.473 (Toon) Thermostat (Room Setpoint)
2017-01-02 19:45:08.476 (Toon) Temp (Room Temperature)
2017-01-02 19:45:08.478 (Toon) Lighting 2 (HeatingOn)
2017-01-02 19:45:08.482 (Toon) Lighting 2 (TapwaterOn)
2017-01-02 19:45:08.485 (Toon) Lighting 2 (PreheatOn)
2017-01-02 19:45:08.489 (Toon) P1 Smart Meter (Unknown
- HansieNL
2017-01-03 02:15:14.539 (Toon Thermostaat) P1 Smart Meter (Elektra)
2017-01-03 02:15:14.552 (Toon Thermostaat) P1 Smart Meter (Gas)
Does it already show the right values on the thermostat?
Blah blah blah
Never mind, I'm not patient enough. Today the values are filled and the meter has arrived in Domoticz.
- Domoticz version: 3.8153
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
kurniawan77 wrote: ↑Wednesday 02 March 2016 9:38Nailed it!!! Issue solved by configuring your local IP addresses in settings (no username and password)marktn wrote:kurniawan77 wrote: I could give it a try... Beloof niks
See PM![]()
hi guys, i hav ethe same issues but i cannot find what it is.. can you guys give any advise?
what do you mean by "Issue solved by configuring your local IP addresses in settings (no username and password)"?
here are my settings.
Domoticz 3.8153 on linux laptop ubuntu 17.10 | Toon Thermostat | RFlink usb gateway
- Domoticz version: Latest
Is it possible to read the (slimmeMeter P1) data from the toon?
