Actual posisition Awning not correct Topic is solved
Rik60
Domoticz version: 2026.3
Post by Rik60 »
Upgrated and tested version 5.4.6. There is a problem with the position with the awning, if i give the awning a setpoint of 25% with the slider, the slider is on 25% and the awning starts to move. If the awning reach the 25% it stops but the slider jumps to 100%.
Tried to open an issue on github but (still) not possible for me.
Edit: Somfy for Domoticz plugin.
imautohuttraeger
Domoticz version: latest
Re: Actual posisition Awning not correct
Post by imautohuttraeger »
In case there will be no response on this thread: As there is no possibility to create an issue at GitHub, I suggest to write a direct message via this forum to the author (@MadPatrick).
Stop, look and listen.
Rik60
Post by Rik60 »
Madpatrick has solved the problem in software version 5.4.7. Working fine now.
@Madpatrick, thanks for the quick fix.
