Enocean USB Stick defect or domoticz newest beta problem with enocean? Topic is solved
sailmich
Post by sailmich »
Rpi zero W / Domoticz newest beta / Enocean USB ESP3 / several eltako window switches / one eltako repeater
Hello I run into problems with my setup. For a couple of months my system runs stabil. Now first it starts to loose some signals from window switches and now I can't get any signal from the switches. When switching a eltako window switch I see a small diode on USB ESP3 is going on so it looks like the signal runs to the ESP3. I got some strange devices in my device list.
Strange devices
Strange devices
Bildschirmfoto vom 2021-03-06 07-52-27.png (56.58 KiB) Viewed 910 times
Domoticz log:
 2021-03-06 07:36:26.229 Status: EnOcean: Worker started...
2021-03-06 07:36:26.248 Status: EventSystem: reset all events...
2021-03-06 07:36:26.251 Status: NotificationSystem: thread started...
2021-03-06 07:36:26.281 Status: PluginSystem: Entering work loop.
2021-03-06 07:36:26.336 Status: EventSystem: reset all device statuses...
2021-03-06 07:36:26.450 Status: EnOcean: Using serial port: /dev/ttyUSB0
2021-03-06 07:36:26.450 Status: EnOcean Send: 55 00 01 00 05 70 08 38
2021-03-06 07:36:26.450 Status: EnOcean Send: 55 00 01 00 05 70 03 09
2021-03-06 07:36:26.538 Status: EnOcean: 02 (05/01) 00 FF F7 D0 80 0A
2021-03-06 07:36:26.538 Status: EnOcean: Transceiver ID_Base: 0xfff7d080
2021-03-06 07:36:26.732 Status: EnOcean: 02 (21/00) 00 02 0F 00 00 02 06 09 00 05 8D EF A1 45 4F 01 03 47 41 54 45 57 41 59 43 54 52 4C 00 00 00 00 00
2021-03-06 07:36:26.732 Status: EnOcean: Version_Info, App: 02.0f.00.00, API: 02.06.09.00, ChipID: 05.8d.ef.a1, ChipVersion: 45.4f.01.03, Description: GATEWAYCTRL
2021-03-06 07:36:27.660 Status: Python EventSystem: Initalizing event module.
2021-03-06 07:36:27.676 Status: EventSystem: Queue thread started...
2021-03-06 07:36:27.673 Status: EventSystem: Started
How can I check where the problem, beside me in front of my PC :), is located?
Any help appreciated!
sailmich
Re: Enocean USB Stick defect or domoticz newest beta problem with enocean?
Post by sailmich »
I couldn't solve it so I installed buster lite and domoticz stable. Seems to running.
labelette91
Post by labelette91 »
hello,
it seems it is the same problem as seem in "problem with Enocean device #4860".
cdt
