MQTT no connection with ip adres.. Topic is solved
OedzesG
Post by OedzesG »
Hope someone can help me out with Mosquitto....
when ik connect Domoticz to mosquitto using: localhost or 127.0.0.1 Domoticz is connecting the right way to mosquitto, but when i use the exact ip adress: 192.168.178.17 in this case, the connection fails.
For Domoticz localhost is ok, but i need to connect another machine inside the localnetwork where the connection over and over fails....
Thnx!
FireWizard
Re: MQTT no connection with ip adres..
Post by FireWizard »
Hi, @OedzesG,
Just a simple question.
Do you have a Firewall installed on your device, that might be blocking port 1883?
Any other device between the two devices with a Firewall, such as a router?
OedzesG
Post by OedzesG »
Tnx for answer,
i allowd Ubuntu firewall (in my case) all the ports and ip adresses.
Problem is solved by adding
# Local MQTT
listener 1883
# End Local MQTT
to the mosquitto.conf.
