Shelly plugin deleted -> problem for Domoticz Topic is solved
Tukker
Domoticz version: 2023.2
Post by Tukker »
I had a Shelly plugin which I deleted from ~/domoticz/plugins
Now my log file shows
 2020-08-16 15:01:59.170 Error: (ShellyCloudPlugin) failed to load 'plugin.py', Python Path used was ':/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2020-08-16 15:01:59.170 Error: (Shelly) Module Import failed, exception: 'ModuleNotFoundError'
2020-08-16 15:01:59.170 Error: (Shelly) Module Import failed: ' Name: plugin'
2020-08-16 15:01:59.170 Error: (Shelly) Error Line details not available.
followed by a line every 15 seconds
2020-08-16 15:15:20.288 Error: Shelly hardware (10) thread seems to have ended unexpectedly
How can I undo this?
Bugs bug me.
FireWizard
Re: Shelly plugin deleted -> problem for Domoticz
Post by FireWizard »
@HvdW
Did you also delete the plugin from your "hardware" in Domoticz (Setup > Hardware)?
Tukker
Post by Tukker »
I can click and reach all menus except Hardware.
Clicking on Hardware does not give a reaction.
Bugs bug me.
FireWizard
Hi, @HvdW
This is a different problem, which I never have seen before. Anyone?
But indirectly, you answered my question. You did not delete the plugin in Hardware.
You should first repair the access to the "Hardware" in the Setup menu and then delete the plugin.
However I don't know, yet, what the reason for that is.
Tukker
Post by Tukker »
Domoticz turned into a state unreachable in the web interface.
I restarted it several times.
Hardware showed up.
Deleted Shelly.
Logs are clean now.
Thanks a lot.
I was at the brink of installing a RPI backup.
Bugs bug me.
