Toon Energy Readings on Domoticz
anandus
Re: Toon Energy Readings on Domoticz
Post by anandus »
I have Zon op Toon, but I can't see it under Toon in devices.
I do see the P1-meter (usage and return), but not the Zon op Toon-Kwh meter.
What do I need to do to see the generated power in Domoticz?
Martijn85
Domoticz version: Stable
Post by Martijn85 »
My Toon device has arrived today. I have added the hardware in Domoticz, all seems to work very well.
I don`t see any KWh meter, i only have the gas meter. Is this option not available anymore?
2017-01-02 19:44:31.423 ToonThermostat: Worker started...
2017-01-02 19:45:08.473 (Toon) Thermostat (Room Setpoint)
2017-01-02 19:45:08.476 (Toon) Temp (Room Temperature)
2017-01-02 19:45:08.478 (Toon) Lighting 2 (HeatingOn)
2017-01-02 19:45:08.482 (Toon) Lighting 2 (TapwaterOn)
2017-01-02 19:45:08.485 (Toon) Lighting 2 (PreheatOn)
2017-01-02 19:45:08.489 (Toon) P1 Smart Meter (Unknown
HansieNL
Post by HansieNL »
2017-01-03 02:15:14.539 (Toon Thermostaat) P1 Smart Meter (Elektra)
2017-01-03 02:15:14.552 (Toon Thermostaat) P1 Smart Meter (Gas)
Does it already show the right values on the thermostat?
Blah blah blah
Martijn85
Post by Martijn85 »
Never mind, I'm not patient enough. Today the values are filled and the meter has arrived in Domoticz.
michaelm86
Domoticz version: 3.8153
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Toon Energy Readings on Domoticz
Post by michaelm86 »
kurniawan77 wrote: Wednesday 02 March 2016 9:38
marktn wrote:
kurniawan77 wrote: I could give it a try... Beloof niks
See PM
Nailed it!!! Issue solved by configuring your local IP addresses in settings (no username and password)Image
hi guys, i hav ethe same issues but i cannot find what it is.. can you guys give any advise?
what do you mean by "Issue solved by configuring your local IP addresses in settings (no username and password)"?
here are my settings.
Domoticz 3.8153 on linux laptop ubuntu 17.10 | Toon Thermostat | RFlink usb gateway
PeJeWe
Domoticz version: Latest
Post by PeJeWe »
Is it possible to read the (slimmeMeter P1) data from the toon?
