nodemcu and communicate with domoticz problem Topic is solved
Everything about esp8266 and more.
reza
Domoticz version: 2024.4
Post by reza »
hi friends
i see this page (https://www.domoticz.com/wiki/ESP8266_WiFi_module) and i want use IDE for nodemcu for communicate.
i use this code for communicate test but dont work.
Do I need to do on raspberry and domoticz?
#include <Wire.h>
#include <ESP8266WiFi.h>
#define MY_ESP8266_SSID "*****"
#define MY_ESP8266_PASSWORD "*****"
// int status = WL_IDLE_STATUS;     // the Wifi radio's status
WiFiClient client;
// domoticz
 const char * domoticz_server = "192.168.1.200"; //Domoticz port
 int port = 8080; //Domoticz port
 int idx = 61; //IDX for this virtual sensor, found in Setup -> Devices
 float A = 70;
 float B = 80;
 void setup()
 void loop()
    printInfo();
    delay(60000); // Wait 60 seconds
 void printInfo()
    // Domoticz format /json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEMP;HUM;HUM_STAT
    if (client.connect(domoticz_server,port)) {
        client.print("GET /json.htm?type=command&param=udevice&idx=");
        client.print(idx);
        client.print("&nvalue=0&svalue=");
        client.print(A);
        client.print(";");
        client.print(B);
        client.print(";0"); //Value for HUM_STAT. Can be one of: 0=Normal, 1=Comfortable, 2=Dry, 3=Wet
        client.println(" HTTP/1.1");
        client.print("Host: ");
        client.print(domoticz_server);
        client.print(":");
        client.println(port);
        client.println("User-Agent: Arduino-ethernet");
        client.println("Connection: close");
        client.println();
        client.stop();
zak45
Domoticz version: V2024.4
Re: nodemcu and communicate with domoticz problem
Post by zak45 »
have begin to work with this device also.
ESPEasy ... so easy :
https://www.letscontrolit.com/wiki/index.php/ESPEasy
reza
Post by reza »
zak45 wrote:Hi,
thank you dear zak, i will see and read this.
reza
Post by reza »
zak45 wrote:Hi,
hi zak. i see espeasy and this is intersting,but 2 question .thank you.
espeasy just used for sensors and just for send message to controller? if i want connect nodemcu to a relay module and control this with domoticz so i can not ??
also in this link in the end of page https://www.domoticz.com/wiki/ESP8266_WiFi_module i think we can use arduino and nodemcu without espeasy.is this true ?
zak45
Post by zak45 »
Control relay: yes
https://www.letscontrolit.com/wiki/index.php/Relays
https://www.letscontrolit.com/wiki/index.php/Relais
ESPeasy if only another firmware .. but very easy to use and directly linked with Domoticz.. really nice.
if you want nodemcu .. no problem, just more programming is needed.
reza
Post by reza »
zak45 wrote:Control relay: yes
thank you dear friend
