Configuration Parameters Topic is solved
Edsardio
Post by Edsardio »
So as I'm working on a project with the aeotec multisensor 6 http://aeotec.com/z-wave-sensor
Now I'm configuring the sensors so they work like I want them to behave.
As I don't want to use domoticz to set the parameters I got a few questions.
When saving my node configurations, what values does the dropdown send? As i can imagine it won't send "disabled/enabled".
In my screenshot I expect parameter 3 to send a "240" value. But what does parameter 4 send?
At the moment I'm only interested in the following parameters
2 – No
3 – 240
4 – Enabled level 5 (maximum sensitivity)
5 – Basic Set (Default)
9 – 0
39 – 20
40 – disabled
41 – 20
42 – 10
43 – 100
44 – 10
45 – 2
46 – disabled
101 – 241
102 – 0
103 – 0
111 – 30
112 – 30
113 – 30
201 – 0
202 – 0
203 – 0
204 – 0
252 – disable
2000 – 240
I want to configure them with openZwave so I expect it is something like this
(homeid, nodeid, parameter, value)
setConfigParam(1, 23, 3, 240);
http://www.openzwave.com/dev/classOpenZ ... nager.html
I hope you guys can help me out.
Greetings,
Edsardio
Edsardio
Re: Configuration Parameters
Post by Edsardio »
I figured it out.
So for anyone else having this problem...
setConfigParam(1, 23, 2, 0);
setConfigParam(1, 23, 4, 5);
setConfigParam(1, 23, 5, 1);
setConfigParam(1, 23, 9, 0);
setConfigParam(1, 23, 39, 20);
setConfigParam(1, 23, 40, 0);
setConfigParam(1, 23, 41, 20);
setConfigParam(1, 23, 42, 10);
setConfigParam(1, 23, 43, 100);
setConfigParam(1, 23, 44, 10);
setConfigParam(1, 23, 45, 2);
setConfigParam(1, 23, 46, 0);
setConfigParam(1, 23, 48, 1);
setConfigParam(1, 23, 101, 241);
setConfigParam(1, 23, 102, 0);
setConfigParam(1, 23, 103, 0);
setConfigParam(1, 23, 111, 30);
setConfigParam(1, 23, 112, 30);
setConfigParam(1, 23, 113, 30);
setConfigParam(1, 23, 201, 0);
setConfigParam(1, 23, 202, 0);
setConfigParam(1, 23, 203, 0);
setConfigParam(1, 23, 204, 0);
setConfigParam(1, 23, 252, 0);
setConfigParam(1, 23, 2000, 240);
0 = disabled
1 = enabled
And for parameter 5 its
0 = disabled
1 = enabled low sensitivity
2 = enabled
3 = enabled
4 = enabled
5 = enabled highest sensitivity
(each level will rise the sensitivity)
Greetings,
Edsardio
