Enable domoticz logging Windows service Topic is solved
loki
Post by loki »
How can I enable domoticz logging under windows when running as a service?
The service is starting "C:\Program Files (x86)\Domoticz\nssm.exe" and not "C:\Program Files (x86)\Domoticz\domoticz.exe".
""C:\Program Files (x86)\Domoticz\nssm.exe" -loglevel 0 -log c:\temp\domo.txt" is not working :(
Regards,
loki
Re: Enable domoticz logging Windows service
Post by loki »
Switch over to linux.
Problem solved.
regards,
JohnAdders
Post by JohnAdders »
You can change the service command line by changing the registry at key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Domoticz\Parameters
And the Value named AppParameters
