I downloaded the latest Ubuntu LTS Desktop and tried to install Domoticz.
I use the following code:
sudo apt curl -sSL install.domoticz.com | sudo bash
but i get the following error:
command line option 's' [from -sSL] is not understood in combination with the other options.
Anyone who knows what is going wrong?
regards,
installing ubuntu error Topic is solved
Re: installing ubuntu error
Check these howto's: https://sancla.com
- erem
- Domoticz version: 2021.1
it's not
it is
sudo curl -sSL install.domoticz.com | sudo bash
it is
Regards,
Rob
Rob
correct, thanks
jackwan1
- Domoticz version: 2020.2
I used the correct curl command, but I got Error 404 Not Found at the end. What could be the problem? I am using Ubuntu 18.04
foxmulder06
What is your OS version: 32 or 64 bits ?
As far as I know, and I was obliged to do it like this, the Binary is only available for 64 bits platform, therfore if you have a 32 bits platform, the binary is not available anymore and give you an error message...
I read on the Screen capture the text "i686" that confirms that you have a 32 bits platform...
Solution: The only way to get Domoticz running on a 32 bits platform is to "compil" it on your platform, after getting the Source code.
Please follow link: https://www.domoticz.com/wiki/Build_Do ... om_source
Note: I did it without any problems on "Ubuntu 18.04.4 LTS" + INTEL ATOM 32bits + Domoticz latest release V2020.2
I created an installation process, fully automated by Shell script that do ALL stuff automatically...
Good luck !
Good luck !
_____________________________________
Pascal
Pascal
