I do not have devices on the devices tab with the latest beta on a rpi 3b with buster.
Only Chroome has this problem. I tried it with MS Edge, everything OK!
I delete the cache (f12), no solution.
Domoticz is working fine, and all the events are executed….
No devices on devices tab in config Topic is solved
pvklink
- Domoticz version: latest b
Jablotron connection, Ikea
pvklink
Re: No devices on devices tab in config
dont know if thi helps
pvklink
Is there error in the Domoticz log?
What kind of sensors did you have? If you add the hardware sensor, is that making any difference?
Curious problem though
Check these howto's: https://sancla.com
pvklink
solved it...
Dont now exactly how...
Dit change some advanced chrome site settings....probably to much...
