For the past 5 years or so I have been successfully using Domotixz RFXcom to operate my Louvolite one touch blinds until last week when the lithium battery gave up. It was then I found out that the r1710 motor was discontinued and replaced with the r1912. I installed the new motor and followed the process I did before to flash the RFXcom with type 2 firmware in order to learn the blinds T0 code but it didn't receive anything. I did manage to get it to learn the code by selecting blinds T1.
The issue I have now is that when I revert to the usual EXT 2 firmware, the blinds wont work. they will work with the type 2 firmware but when I use this I can't receive data from my owl energy monitors.
I hope this all makes sense. I'm basically asking is there a firmware which I can use to operate both owl and the new Lovolite blinds?
RFXCom Firmware Question Topic is solved
markk
markk
Re: RFXCom Firmware Question
This is solved. I managed to get both working using Version: Ext2/1025 firmware.markk wrote: Thursday 05 August 2021 21:02 For the past 5 years or so I have been successfully using Domotixz RFXcom to operate my Louvolite one touch blinds until last week when the lithium battery gave up. It was then I found out that the r1710 motor was discontinued and replaced with the r1912. I installed the new motor and followed the process I did before to flash the RFXcom with type 2 firmware in order to learn the blinds T0 code but it didn't receive anything. I did manage to get it to learn the code by selecting blinds T1.
