Notifications, source?
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
Patricen
Domoticz version: Beta rel
Post by Patricen »
Hello, i'm receiving notifications through Telegram but i'm unable to find where they are coming from.
The history: I do have trvs that were "eating" batteries. I then decided to send a notification with a specific message as soon as the temperature was not reported after a certain time.
I fixed the issue for the trvs, removed the notification but i'm still receiving it.
Any clue?
willemd
Domoticz version: 2024.1
Re: Notifications, source?
Post by willemd »
Configuration for telegram is in the settings.
notifications can then be sent from many places, for example
1) from a device directly
2) from a plugin
3) from dzvents
4) using a json command
Patricen
Post by Patricen »
Ok thanks. Due to the notification text that is sent, it is something sent directly from a device as it was configured as follows
Image.
The issue is that I did delete the notifications from devices but they are still pushed through Telegram.
I checked Domoticz.db database integrity that is ok and tried to find the specific notification message within the database without success.
It looks like there is still an issue, can somebody help about that?
Capture d’écran 2026-02-18 113424.png (69.29 KiB) Viewed 130 times
willemd
Post by willemd »
Your two screenprints still show an active notification. Did you select the notifcation and then press delete? Or did you press clear in the bottom right corner?
