Earthquake info from KNMI
janpep
Domoticz version: 2025.1
Re: Earthquake info from KNMI
Post by janpep »
I give it another try.
1. Remove your current script aardbevingen. You mixed everything in there.
2. Open a new DZvents script. Remove the template data and then paste the following in there. It holds the global helper functions.
I cleared it from content that has nothing to do with the current script.
Tip. Never only paste and run code. Read the comments. Try to understand what it does, before it is running FORMAT C: :-)
Save it with the name: global_data
-- 05-01-2023: Script created by Jan peppink, https://ict.peppink.nl
-- This scripts holds all the globally persistent variables and helper functions
-- See the documentation in the wiki
-- NOTE: THERE CAN BE ONLY ONE global_data SCRIPT in your Domoticz install.
	-- Global persistent data
	data = {
		-- Global variables below here.
	-- Global helper functions
	helpers = {
		-- Used in t-Alarmeringen, t-Earthquake-KNMI,
	   getUTCtimediffseconds = function(qUnixtime)
			local timezone = os.date('%z', qUnixtime)   -- "+0200"
			local signum, hours, minutes = timezone:match '([+-])(%d%d)(%d%d)'
			local lTimediff = (tonumber(signum..hours)*3600 + tonumber(signum..minutes)*60)
			return lTimediff
		end,
		-- Used in t-Earthquake-KNMI, t-Airplanes,
		calculateDistance = function( lat1, lon1, lat2, lon2)
			-- Calculate distance using Haversine formula
			local R = 6371 -- Earth radius in kilometers
			local dLat = math.rad(lat2 - lat1)
			local dLon = math.rad(lon2 - lon1)
			local a = math.sin(dLat / 2) * math.sin(dLat / 2) + math.cos(math.rad(lat1)) * math.cos(math.rad(lat2)) * math.sin(dLon / 2) * math.sin(dLon / 2)
			local c = 2 * math.atan2(math.sqrt(a), math.sqrt(1 - a))
			local distance = R * c
			return distance
		end,
-- That's All --------------------------------------------------
3. Then open a new DZvents script. Remove the template data and then paste the following in there.
A. Change IDX number and Email.
B. Save it as Aarbevingen-KNMI or what you want.
-- 07-05-2024 script by Jan Peppink, https://ict.peppink.nl
-- Based on earlier script found on https://www.domoticz.com/forum/viewtopic.php?t=41380
-- Missed Dutch earthquakes. Modified script to get info from KNMI Aardbevingen RSS.
-- Parse XML result to get info from the most recent of 30 in the list.
-- URL = https://cdn.knmi.nl/knmi/map/page/seismologie/GQuake_KNMI_RSS.xml
-- Function 'getUTCtimediffseconds' expected in global_data.
-- 09-05-2024 Directly make use of dz.log instead of the 'logthis' function in global_data.
-- 10-05-2024 Again some adjustments to the log function.
-- 13-05-2024 Added font color for hyperlinks.
-- 21-05-2024 Sometimes error on local atUTCtime = description_table[1] .. ' ' .. string.sub( description_table[2], 2, 6 )
--			bad argument #1 to 'sub' (string expected, got nil); However - Manually never seen.
--- Your settings ----------------------------------------------------------------
-- First set the used device index numbers and variables you might want to change.
local alertIdx = 99999		   -- Set to the idx of the Virtual Alert sensor you have to create for this script
local mailto = '[email protected]' -- Set E-mail adres to sent notification to.
local knmiURL = 'https://cdn.knmi.nl/knmi/map/page/seismologie/GQuake_KNMI_RSS.xml'
-- Define distance for ALERTLEVEL colors
-- From dClose to the maxRadius we get: ALERTLEVEL_GREY
local dClose = 300		  -- From distance dCloser to dClose: ALERTLEVEL_YELLOW
local dCloser = 200		 -- From distance dClosest to dCloser: ALERTLEVEL_ORANGE (+ eMail notification)
local dClosest = 100		-- From distance 0 to closest: ALERTLEVEL_RED (+ eMail notification)
		timer = {
			--'every 2 minutes',  -- Only for testing.
			'at *:02',
			'at *:07',
			'at *:12',
			'at *:17',
			'at *:22',
			'at *:27',
			'at *:32',
			'at *:47',
			'at *:52',
			'at *:57',
		httpResponses = {
			'knmi-rss'   -- matches callback string below
	logging = {
		-- Level can be domoticz.LOG_INFO, domoicz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG, domoticz.LOG_ERROR or domoticz.LOG_FORCE
		level = domoticz.LOG_INFO,
		--level = domoticz.LOG_DEBUG,
		marker = 'KNMI-',
	execute = function( dz, triggeredItem )
		-- Set Local environment=================
		local _u = dz.utils	   -- Holds subset of handy utilities.
		local _h = dz.helpers	 -- Holds the global functions.
		--local _d = dz.globalData  -- Holds the global data.
		-- Set your loccation coordinates from Domoticz settings =================
		local yourLatitude = dz.settings.location.latitude
		local yourLongitude = dz.settings.location.longitude
		-- Use color variable for hyperlink font color
		htmlColor = 'Blue'
		-- Set your alert device index to store the result.
		local alertLevel = dz.ALERTLEVEL_GREY -- Holds the alertLevel (color) to set
		local alertText = ''
		local lastalertText = dz.devices(alertIdx).text   -- Holds string of the previous round.
		local lTimediff = 0	 -- Calculate diff in seconds between UTC and local time of this event.
		local delString = ""	-- Holds (sub) string to delete.
		-- Local Functions go here =============
		local function calculateDistance(lat1, lon1, lat2, lon2)
			return distance
		-- Now start to do something ============
		if (triggeredItem.isTimer) then
			dz.openURL({
				url = knmiURL,
				method = 'GET',
				callback = 'knmi-rss'
		if (triggeredItem.isHTTPResponse) then
			-- Process the obtained data.
			if (triggeredItem.ok and triggeredItem.isXML) then
				-- We have something, which looks like this:
				--<rss xmlns:geo="http://www.w3.org/2003/01/geo/wgs84_pos#" xmlns:georss="http://www.georss.org/georss" version="2.0">
				--  <channel>
				--	  <copyright>Copyright KNMI</copyright>
				--	  <description>KNMI - de laatste 30 registraties van aardbevingen en andere seismo-akoestische bronnen in en rondom Nederland</description>
				--	  <title>KNMI - de meest recente registraties van aardbevingen en andere seismo-akoestische bronnen in en rondom Nederland</title>
				--	  <item>
				--		  <title>2024-05-05, 't Zandt, M=0.3</title>
				--		  <description>2024-05-05, 19:14:45, Lat = 53.357, Lon = 6.783, Diepte = 3.0 km, M = 0.3, Plaats = 't Zandt, Author = KNMI, Type = Geinduceerd, Analyse = Reviewed</description>
				--		  <geo:lat>53.357</geo:lat>
				--		  <geo:lon>6.783</geo:lon>
				--		  <georss:point>53.357 6.783</georss:point>
				--		  <link>http://www.knmi.nl/nederland-nu/seismologie/aardbevingen/knmi2024ivvz</link>
				--		  <guid>knmi2024ivvz</guid>
				--	  </item>
				local result_table = triggeredItem.xml
				if type( result_table ) == "table" then
					dz.log( 'result_table: type = ' .. type(result_table), dz.LOG_DEBUG )
					-- Get only the info from the first item.
					-- Get link to page with details.
					dz.log( 'URL details = ' .. result_table.rss.channel.item[1].link, dz.LOG_DEBUG )
					local qUrl = tostring( triggeredItem.xml.rss.channel.item[1].link )
					-- The complete description to split up. Put it in a table.
					dz.log( 'Full description string = ' .. result_table.rss.channel.item[1].description, dz.LOG_DEBUG )
					local description_table = _u.stringSplit( result_table.rss.channel.item[1].description, ',' )
					-- Get time (= UTC time) from the description_table.
					-- Record 1 = 2024-05-05; Record 2 = 19:14:45 (strip the seconds)
					dz.log( 'String 1 = "' .. description_table[1] .. '" en String 2 = "' .. description_table[2] .. '"', dz.LOG_DEBUG )
					atUTCtime = dz.time.dateToDate( atUTCtime, 'yyyy-mm-dd hh:MM', 'dd-mm-yyyy hh:MM', 0 )
					dz.log( 'atUTCtime = ' .. atUTCtime, dz.LOG_DEBUG )
					-- Calculate the Local time.
					local qUnixtime = dz.time.dateToTimestamp( atUTCtime, 'dd-mm-yyyy hh:MM' )
					lTimediff = _h.getUTCtimediffseconds( qUnixtime )
					local atLocalTime = dz.time.timestampToDate( qUnixtime, 'dd-mm-yyyy hh:MM', lTimediff )
					dz.log( 'atLocalTime = ' .. atLocalTime, dz.LOG_DEBUG )
					-- Record 3 = Lat = 53.357
					delString = "Lat = "
					local qLat = tostring(description_table[3]):gsub( delString, "" )
					dz.log( 'qLat = ' .. qLat, dz.LOG_DEBUG )
					-- Record 4 = Lon = 6.783
					delString = "Lon = "
					local qLon = tostring(description_table[4]):gsub( delString, "" )
					dz.log( 'qLon = ' .. qLon, dz.LOG_DEBUG )
					-- Record 5 = Diepte = 3.0 km
					delString = "Diepte = "
					local qDepth = tostring(description_table[5]):gsub( delString, "" )
					dz.log( 'qDepth = ' .. qDepth, dz.LOG_DEBUG )
					-- Record 6 = M = 0.3
					delString = "M = "
					local qMag = tostring( description_table[6]):gsub( delString, "" )
					dz.log( 'qMag = ' .. qMag, dz.LOG_DEBUG )
					-- Record 7 = Plaats = 't Zandt
					delString = "Plaats = "
					local qPlace = tostring(description_table[7]):gsub( delString, "" )
					dz.log( 'qPlace = ' .. qPlace, dz.LOG_DEBUG )
					-- Record 8 = Author = KNMI
					local qAuthor = description_table[8]
					dz.log( 'qAuthor = ' .. qAuthor, dz.LOG_DEBUG )
					-- Record 9 = Type = Geinduceerd
					local qType = description_table[9]
					dz.log( 'qType = ' .. qType, dz.LOG_DEBUG )
					-- Record 10 = Analyse = Reviewed
					-- Calculate distance from home location.
					local distance = calculateDistance( yourLatitude, yourLongitude, qLat, qLon )
					-- Round the distance to the nearest kilometer
					local roundedDistance = _u.round( distance, 0 )
					--Set Alertlevel color based on distance.
					if roundedDistance < dClosest then
						alertLevel = dz.ALERTLEVEL_RED
					elseif roundedDistance >= dClosest and roundedDistance < dCloser then
						alertLevel = dz.ALERTLEVEL_ORANGE
					elseif roundedDistance >= dCloser and roundedDistance < dClose then
						alertLevel = dz.ALERTLEVEL_YELLOW
					--Set and format the new alertText
					local alertText = tostring( atLocalTime .. ' uur in ' .. qPlace .. '\n' .. 'Magnitude: ' .. qMag .. '. Diepte: ' .. qDepth .. '. Afstand: ' .. roundedDistance ..' km.\n' .. '<a href="https://maps.google.com/?q=' .. qLat .. ',' .. qLon .. '" target="_blank"><span style="color: ' ..  htmlColor .. '">Toon locatie</span></a>' .. ' - ' .. '<a href="'  .. qUrl ..  '" target="_blank"><span style="color: ' ..  htmlColor .. '">Toon bron</span></a>' )
					dz.log( 'LastalertText = ' .. lastalertText, dz.LOG_DEBUG )
					dz.log( 'NewalertText = ' .. alertText, dz.LOG_DEBUG )
					-- Only update and send mail when info has changed. and
					if alertText ~= lastalertText then
						-- We have new information, so update the device.
						dz.devices(alertIdx).updateAlertSensor( alertLevel, alertText )
						-- Only send email when it comes closer then dCloser
						if roundedDistance <= dCloser then
							--Set and format the new mail message
							local message = tostring('Plaats: ' .. qPlace .. '<br>' ..
							'Magnitude: ' .. qMag .. '<br>' ..
							'Diepte: ' .. qDepth .. '.<br>' ..
							'Lokale Tijd: ' .. atLocalTime .. ' uur.<br>' ..
							'UTC Tijd: ' .. atUTCtime .. ' uur.<br>' ..
							'Afstand: ' .. roundedDistance .. 'km.<br>' ..
							'Coördinaten: ' .. qLat .. ','.. qLon .. '<br>' ..
							qAuthor .. '<br>' ..
							qType .. '<br>' ..
							'<a href="https://maps.google.com/?q=' .. qLat .. ',' .. qLon .. '">Toon locatie</a>' .. '<br>' ..
							'<a href="' .. qUrl .. '">Toon bron</a>' .. '<br>' )
							-- Send the mail
							dz.email( 'Aardbeving ' .. qPlace, message, mailto, 0 )
					dz.log( 'No result_table found', dz.LOG_ERROR )
				dz.log( 'Item or XML - NOT OK', dz.LOG_ERROR )
Hope this helps.
Dz on Ubuntu VM on DS718+ behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
Fredom
Domoticz version: 2022.2
Post by Fredom »
janpep wrote: Saturday 06 July 2024 21:05 I give it another try.
	data = {
	helpers = {
			return lTimediff
		end,
			return distance
		end,
		timer = {
			'at *:02',
			'at *:07',
			'at *:12',
			'at *:17',
			'at *:22',
			'at *:27',
			'at *:32',
			'at *:47',
			'at *:52',
			'at *:57',
		httpResponses = {
	logging = {
		marker = 'KNMI-',
		htmlColor = 'Blue'
			return distance
			dz.openURL({
				url = knmiURL,
				method = 'GET',
				--  <channel>
				--	  <item>
				--	  </item>
					delString = "M = "
							qType .. '<br>' ..
							-- Send the mail
Hope this helps.
It works perfectly now.
Thanks for the script and the clear explanation
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Buster - Domoticz 2022.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
janpep
Post by janpep »
Great.
And if I am right you got two earthquakes in Middelstum and Loppersum short after your post. :-)
Fredom
Post by Fredom »
janpep wrote: Sunday 07 July 2024 13:11 Great.
Yes correct
Yours sincerely,
Fred
janpep
Post by janpep »
I forgot to update here.
URL only gives old data. It has changed.
Here the updated script with new URL.
A limit can be given. I have set it to 1, because only the most recent one is used.
Change your device idx and e-mail address.
-- 2025-01-31 URL changed. Can set limit in the URL So, now get only last one.
--            https://rdsa.knmi.nl/abcws/event/query?format=rss&limit=1
local mailto = 'YourEmailAddress'  -- Set to your E-mail adres to sent notification to.
local knmiURL = 'https://rdsa.knmi.nl/abcws/event/query?format=rss&limit=1'
		timer = {
			'at *:02',
			'at *:07',
			'at *:12',
			'at *:17',
			'at *:22',
			'at *:27',
			'at *:32',
			'at *:47',
			'at *:52',
			'at *:57',
		httpResponses = {
    logging = {
		-- Level can be domoticz.LOG_INFO, domoticz.LOG_STATUS, domoticz.LOG_ERROR or domoticz.LOG_DEBUG
		level = domoticz.LOG_STATUS,
    	marker = 'KNMI-',
        htmlColor = 'Blue'
			return distance
			dz.openURL({
			    url = knmiURL,
				method = 'GET',
                --  <channel>
                --      <item>
                --      </item>
                    dz.log( 'URL details = ' .. result_table.rss.channel.item.link, dz.LOG_DEBUG )
                    local qUrl = tostring( result_table.rss.channel.item.link )
                    dz.log( 'Full description string = ' .. result_table.rss.channel.item.description, dz.LOG_DEBUG )
                    local description_table = _u.stringSplit( result_table.rss.channel.item.description, ',' )
                    delString = "M = "
                            qType .. '<br>' ..
                            -- Send the mail
