As you can see in the screenshot enclosed, I have 13 Domoticz items in Utility tab (One Thermostat and 12 smart meter P1). But the App shows ONLY 12 items. The one missing is named "COEFF H (W/°Chauffage)". I tried to change its name, but it didn't solve the issue.
Thanks for your answer.
Domoticz App : utility item missing Topic is solved
- Antori91
- Domoticz version: 4.10717
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
- Antori91
Re: Domoticz App : utility item missing
Ouups. There is no issue with the App...The issue was I don't use the same user with the App and with the Chrome browser. I forgot to allow the missing utility meter to the user I use with the App...
So solved !
So solved !
