OpenTherm weather dependent heating control
Maciek90
Re: OpenTherm weather dependent heating control
Post by Maciek90 »
Is this what you meant?
	"Battery" : 255,
	"LastUpdate" : "2025-06-22 14:56:02",
	"RSSI" : 12,
	"description" : "",
	"dtype" : "Temp",
	"hwid" : "47",
	"id" : "145AE",
	"idx" : 1374,
	"name" : "In",
	"nvalue" : 0,
	"org_hwid" : "47",
	"stype" : "LaCrosse TX3",
	"svalue1" : "26.00",
	"unit" : 1
akamming
Post by akamming »
What do the general status and opentherm status of the main screen of the firmware show?
Could you also switch on the "Debug Messages to MQTT", and then post the output of the following command (make sure you do a restart after you typed this command):
mosquitto_sub -t domesphelper/text/DebugToMQTT/state -u <your username> -P <your password>
You should see something like:
07:24:11 Configfile saved
07:24:14 Succesfully (re)connected, starting operations
07:24:15 Time was set
07:24:22 Received message on topic [domoticz/out/2019], payload: [{
        "Battery" : 255,
        "LastUpdate" : "2025-06-23 08:19:56",
        "RSSI" : 12,
        "description" : "",
        "dtype" : "Temp",
        "hwid" : "36",
        "id" : "0002",
        "idx" : 2019,
        "name" : "Ground Temperature (10 cm)",
        "nvalue" : 0,
        "org_hwid" : "36",
        "svalue1" : "16.3",
        "unit" : 2
07:24:22 First temperature (16.30) received, ready for climate mode
07:24:22 PID Mode, PID=(0.00,16.30,73.70), total: 90.00
07:24:23 PID Mode, PID=(0.00,16.30,73.70), total: 90.00
07:24:24 PID Mode, PID=(0.00,16.30,73.70), total: 90.00
07:24:26 PID Mode, PID=(0.00,16.30,73.70), total: 90.00
07:24:27 PID Mode, PID=(0.00,16.30,73.70), total: 90.00
07:24:28 PID Mode, PID=(0.00,16.30,73.70), total: 90.00
Maciek90
Post by Maciek90 »
as in the picture below
14:31:59 PID Mode, PID=(0.00,27.00,-17.00), total: 10.00
14:32:00 PID Mode, PID=(0.00,27.00,-17.00), total: 10.00
14:32:01 PID Mode, PID=(0.00,27.00,-17.00), total: 10.00
14:32:01 Received message on topic [domoticz/out/1374], payload: [{
        "Battery" : 255,
        "LastUpdate" : "2025-06-23 15:32:02",
        "RSSI" : 12,
        "description" : "",
        "dtype" : "Temp",
        "hwid" : "47",
        "id" : "145AE",
        "idx" : 1374,
        "name" : "In",
        "nvalue" : 0,
        "org_hwid" : "47",
        "svalue1" : "27.00",
        "unit" : 1
14:32:02 PID Mode, PID=(0.00,27.00,-17.00), total: 10.00
14:32:03 PID Mode, PID=(0.00,27.00,-17.00), total: 10.00
14:32:05 PID Mode, PID=(0.00,27.00,-17.00), total: 10.00
akamming
Post by akamming »
Maciek90 wrote: Monday 23 June 2025 15:19
        "Battery" : 255,
        "RSSI" : 12,
        "description" : "",
        "dtype" : "Temp",
        "hwid" : "47",
        "id" : "145AE",
        "idx" : 1374,
        "name" : "In",
        "nvalue" : 0,
        "org_hwid" : "47",
        "unit" : 1
It’s working correctly. Your setpoint is set to 19. It recieves a value of 27 so the setpoint for the heating/cooling device is set to 10. What is the issue then?
Maciek90
Post by Maciek90 »
Oh sorry, my mistake! I was looking at the Temperatures>Thermostat>-127 (like in the picture) readings. Now I know that the inside temperature works fine.
I have another problem. What about the outside temperature? I don't have a dedicated outside temperature sensor for the boiler. Until now, I used the sensor in Domoticz. In the plugin, I could provide its IDX. How can I currently use the sensor from Domoticz?
akamming
Post by akamming »
Maciek90 wrote: Tuesday 24 June 2025 10:16 Oh sorry, my mistake! I was looking at the Temperatures>Thermostat>-127 (like in the picture) readings. Now I know that the inside temperature works fine.
outside temperature is the opentherm outside temperature (in other words: it will give a reading if you have an outside temperature attached directly to your boiler)
I understand your point: wasn't aware of it until now, but indeed since you could use any idx for outside temperature using the plugin. when you use the firmware itself as thermostat, you can only use the internal sensor. It is a good idea though, Maybe in the future i will add this capability.
Maciek90
Post by Maciek90 »
Would you be so kind as to try to add this option before the heating season starts? :) I used the option with sensors in Domoticz in combination with the plugin and it worked very well. In the current situation I will have to buy an outside temperature sensor for the boiler.
akamming
Post by akamming »
I put it on my todo list. When I have Some time I Will add it…
Maciek90
Post by Maciek90 »
In that case I'll wait patiently :)
akamming
Post by akamming »
Maciek90 wrote: Tuesday 01 July 2025 18:01 In that case I'll wait patiently :)
i just updated the code, so you can now also use mqtt for the outside temperature.
it's not a setup i use for myself, so i could not test very well. Pls let me know if it works.
Maciek90
Post by Maciek90 »
I'll try it in a few days.
HvdW
Domoticz version: 2023.2
Post by HvdW »
What is the difference between the ihormelnyk gateway and the nodoshop gateway?
Same functionality, different format?
Bugs bug me.
