Tado Thermostat plugin
Domoticz version: 2024.7
Re: Tado Thermostat plugin
jannl wrote: Friday 04 April 2025 8:11 knip
Edit: obviously I asked the wrong question. I had to re-enable Tado through the URL, when is this needed? Every restart?
Probably when you restart Domoticz after more than 30 days as the token is valid for 30 days.
jannl
Domoticz version: 2022.2
Post by jannl »
hm, but no. First token was at 31 march, so that is not it.
Wonder if it is possible to automate that......
... When Domoticz is started another time, it will use the Refresh Token to get a new Access Token
The Refresh Token is valid for 30 days, so you need to start Domoticz within 30 days
In case there is a problem with the refresh token (30 days, or revoked), the Login message is presented again to the end user and you need to go to this URL again
It should work when token is from 31 March
gizmocuz
Post by gizmocuz »
You should not need to refresh the token yourself if you keep Domoticz running.
If you stop Domoticz, wait 31 days, and start Domoticz again, then you need to do the URL thing again.
(Domoticz will tell you this every minute in the Log)
reinestein
Domoticz version: 2023.1
Post by reinestein »
I get this error:
Tado: Failed to retrieve API environment from https://app.tado.com/env.js
Running domoticz 2025.1 build 16672 on docker/unraid. I run the stable version not the latest, because of my Tuya plugin not working.
Any thoughts?
ViperAppie
Post by ViperAppie »
Got the same error since yesterday.
Following the post....
gizmocuz
Post by gizmocuz »
Seems TADO removed an environment API call.
I removed this call, and hard coded the endpoint in beta 16703 (others seem to do this as well)
All seems to be working again now
sloeber70
Domoticz version: latest
Post by sloeber70 »
Hi..
after updating to latest beta:
Version: 2025.1 (build 16703)
Build Hash: adbdd30c1
Compile Date: 2025-05-22 09:41:41
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
works again. thx guys !!!
Kind regards,
Sloeber70
Linux 12 Bookworm standard edition
Domoticz latest beta
