Use GPIO pins from LUA. How? Topic is solved
mjdb
- Domoticz version: all beta
I want to set GPIO-pins from LUA.
I searched the internet and this forum for days, but I can't find the solution.
Main question: What is the "#include" or "require" instruction in LUA to use GPIO-pins from WiringPi?
I installed WiringPi according to the Wiki (https://www.domoticz.com/wiki/GPIO).
On the command line "gpio -v" is working and so is "gpio readall".
Can someone give a LUA example how to call the WiringPi/GPIO library and how to set the GPIO-pins from LUA?
I tried alternatives from internet. None of them gave the final solution.
- WiringPi WIKI is about using GPIO with switches.
- Github is about developing, but I can't find any practical application.
- Installation of http://andre-simon.de/doku/rpi_gpio_lua ... io_lua.php can be completed, but the require "GPIO" in LUA fails.
Side-question: Is the current installation of Domotics using LUA 5.1 or LUA 5.2
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
BarryT
- Domoticz version: 2024.3
Re: Use GPIO pins from LUA. How?
Hi Marco,mjdb wrote:I want to set GPIO-pins from LUA.
What do you want do with the pin(s)?
Sensor reading?
Turn on/off relais?
Blinking a led?
mjdb
I want to build a 'schematic house' with leds in various rooms. The leds should indicate the status of sensors, activities, alarms, lights and other devices.
Since I am using both KaKu, Z-wave and internet-devices I only have the complete overview of all statuses available from within Domoticz.
I have a basic system working with Arduino with copies of received 433MHZ commands, but I also want Z-wave etc.
I want to make a script (preferably in LUA) that says: 'If device X is On' then 'put PIN x High'. So the Led should lighten up.
Because of the number of devices, I am sure I will need to use a shift-register. So executing commands via os.execute probably won't work.
Hope you can help me...
BarryT
First add "dtoverlay=w1-gpio" in /boot/config.txtmjdb wrote:I want to set GPIO-pins from LUA.
Then 'export' the gpio # of your need..
go to etc/init.d/domoticz.sh and add following code, after the line with:
### END INIT INFO
sudo sh -c 'echo 16 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio16/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio16/active_low'The second code is the direction (if needed).
I use relais on the gpio pins, and in Domoticz the states of the relais where on=off and off=on, so i reversed the direction.
The last code is giving the gpio port the output to LOW, so it gives 0 voltage (so closed).
If u want to use the gpio as INPUT, use the same code but then with IMPORT settings..
Do this for every gpio port u want to use.
Repeat this codes to your needs..
Hope you have enough information to play with.
After you added this code into the domoticz.sh, reboot and after that u could use gpio in Domoticz.
Go to Hardware, add GPIO.
Then to go the switches, add manual switch, add gpio..
Edit*
https://www.youtube.com/watch?v=7ve0KLruhU4
See this video for the code in domoticz, and a lua example
if you have inverted logic relays you have to use HW "generic gpio fs" otherwise if you use GPIO only it will only behave the normal way (at least it is what it did on my rpi)
BarryT
gohan wrote:if you have inverted logic relays you have to use HW "generic gpio fs" otherwise if you use GPIO only it will only behave the normal way (at least it is what it did on my rpi)
sudo sh -c 'echo high > /sys/class/gpio/gpio16/direction'On=On Off=Off
that's what I said, but if you add "sudo sh -c 'echo 1 > /sys/class/gpio/gpio16/active_low'" it will continue to work ON=ON OFF=OFF unless in the HW page you add the "generic gpio fs" and then you can do the pin HIGH=OFF LOW=ON
BarryT
Good, allright... But what does this have to do with the question of mjdb, to use gpio in lua?gohan wrote:that's what I said, but if you add "sudo sh -c 'echo 1 > /sys/class/gpio/gpio16/active_low'" it will continue to work ON=ON OFF=OFF unless in the HW page you add the "generic gpio fs" and then you can do the pin HIGH=OFF LOW=ON
mjdb
Thank you Barry!
You helped me a lot. The first trick was to place the GPIO initialization commands in domoticz.sh near the top. In the Wiki it says to put them at the bottom, so after Domoticz is started. This seems not correct.
Now, I have my GPIO-switch in Domoticz. I understand how to use it from LUA. That is a great step forward.
I suppose, for a second switch I have to 'export' another pin.
But... If I want to use a shift-register, I have to send a large series of on/off commands to several pins.
Is there a way to do that from LUA without the use of 'PIN-switches' ?
BarryT
No thanks.mjdb wrote:Thank you Barry!
yes, correct. Do this for every led/switch/input.mjdb wrote:Now, I have my GPIO-switch in Domoticz. I understand how to use it from LUA. That is a great step forward.
What do you mean with pin-switches? I think the only way to use the pin(s) in domoticz is trough switches, inputs or states (high low)?mjdb wrote:But... If I want to use a shift-register, I have to send a large series of on/off commands to several pins.
BarryT
Btw, i cannot help you with questions about the 'shift-register' with a raspberry (in domoticz)..
I don't use it
I don't use it
mjdb
I meant the devices/switches that you define in Domoticz to turn a PIN high or low.What do you mean with pin-switches?
Well, that in fact was/is my main question. Is there a way to use pins (set high/low) without the use of switches?I think the only way to use the pin(s) in domoticz is trough switches, inputs or states (high low)?
Anyway, I have progressed now that I can use at least the available number of pins.
For anyone who comes at this point of the thread... Do you know how to set the pin-state directly from LUA? Without having to wait that the script finishes.
BarryT
Ik denk dan toch echt dat je aan het bashen komt..
Misschien dat het met json mogelijk is middels een http call, maar dat durf ik niet te zeggen.
Neem hier eens een kijkje:
http://iqjar.com/jar/programming-the-ra ... sh-script/
mjdb
Yes, I know. I have the GPIO command from WiringPi working on the command line (see my initial post).Ik denk dan toch echt dat je aan het bashen komt..
I know I can set a series of those commands in a file and run it, for example through os.execute (= LUA command).
The main obstacle will be to use the shift-register. This has to be controlled from three pins with a synchronized (clocked) output.
I will experiment. When I have a solution, I surely will come back here and publish it.
Thank you all for your help till this point.
why do you need shift register? How many outputs do you need?
mjdb
I want to make a "virtual" representation of al devices I have in Domoticz, devided per room.
That is (about) 40 lights, 8 motion sensors, 8 door/window sensors (x 2 open/close = red/green), ventilation, 12 activity-statuses from other sources, physical mailbox, telephone answering-machine, NAS status, power usage (high/low) etc.
In total I assume 80 leds will be needed (or more when I am finished). So that is about 10 shift registers SN74HC595N.
Is it necessary to have such a gadget? Nope! But I want it anyway.
By the way, I have it working with the physical pins from the Raspberry Pi for 14 devices. My next challenge now is the shift register.
mjdb
Re: Use GPIO pins from LUA. The next step...
OK, so I managed to get a shift-register working.
A short explanation: A shift-register can hold up to 8 bits of information, which would be equal to 8 output pins on a Raspberry Pi or an Arduino.
You can combine several shift-registers to hold 16 bits, 24 bits, 32 bits and so on, of information. This is much more than the number of physical pins on a Raspberry Pi. For the transfer of data to the shift-register, you only need 3 pins, independent of the number of bits you will use.
A shift-register has a data-in-pin where the new bit-status is offered and a clock-pin that - when high - imports that data-bit. This is repeated for all 8, 16, 24 etc bits. When all bits are read, the latch-pin must be set high. At that moment the imported bits are copied to the output-pins.
The clock-timing should be about 1 milli-second. Well, this is the part I have not yet solved. If I set switches in Domoticz on and off without delay this goes far to fast for the shift register to process. And the only delay I know of in Domoticz is the 'AFTER 1' seconds option. This is of course way to slow, but... it is nice to follow the process happen.
If you build the following prototype, you can exactly follow what happens.
And from the back:
The connection of the pins is explained in the script.
You can see what the script is sending by the green, blue and white leds:
When the blue led is off, the shift register is ready to receive information.
When the white led is on there is a bit with the ON state presented. When the white led is OFF, there is a bit with the OFF state presented.
When the green led turns ON, the state as indicated by the white led is read and processed by the shift-register.
This is repeated 8 times.
After that you will see the blue led turn on. At that moment, the input-bits are copied to the output-pins of the shift register.
Well, my next challenge is to find a way to set Domoticz switches with an interval of 1 milli-second.
If you would be the one that knows how to achieve this... please tell me.
And from the back:
-- GpioTest
-- Make three gpio-switches in Domoticz.
-- I choose names that tell where the switch is related to.
-- In this script I use variables that indicate the purpose of the switches:
local Latch = 'gpio16 (pin36)'
local Clock = 'gpio17 (pin11)'
local DataIn = 'gpio18 (pin12)'
-- Pins on the 74x595 shift register
-- __ __
-- pin 1, Out 2 | U | pin 16, Vcc
-- pin 2, Out 3 | | pin 15, Out 1
-- pin 3, Out 4 | | pin 14, Data in
-- pin 4, Out 5 | | pin 13, Gnd
-- pin 5, Out 6 | | pin 12, Latch
-- pin 6, Out 7 | | pin 11, Clock
-- pin 7, Out 8 | | pin 10, Vcc
-- pin 8, Gnd |_____| pin 9, Data out
-- 'My' colors for the test
-- Latch; on the 74x595, pin 12 = purple
-- Clock; on the 74x595, pin 11 = green
-- DataIn; on the 74x595, pin 14 = brown
-- Connect pins 16 and 10 to power/plus/Vcc
-- Connect pins 8 and 13 to ground/minus
-- The shift register is powered by 3,3 volt.
-- Otherwise the output-signals of the Raspberry Pi Pins (also 3,3 volt)
-- would not be recognized as high.
-- If you use two (or more) shift-registers, connect pin 9
-- to pin 14 of the next chip.
-- Also connect pin 12 to pin 12 and pin 11 to pin 11.
print ("GpioTest started")
local CmdCount = 0
function SetLow(DeviceName)
-- This function turns OFF the specified switch
-- and so the related gpio-pin.
CmdCount = CmdCount + 1
table.insert(commandArray, {[DeviceName] = 'Off AFTER ' .. tostring(CmdCount)})
function SetHigh(DeviceName)
-- This function turns ON the specified switch
table.insert(commandArray, {[DeviceName] = 'On AFTER ' .. tostring(CmdCount)})
-- These functions use the 'AFTER x' seconds delay.
-- This means that each bit-state-change takes one full second.
-- The shift-in of one data-bit needs four bit-state-changes and therefore 4 seconds.
-- Of course this is way to long, it should be 1 milli-second.
-- For now this is a proof-of-concept that nicely shows how the
-- shift-register works.
SetLow(Latch) -- Freeses the current state of the shift-register
function ShiftOut(DataArray)
SetLow(Clock) -- start clean
SetLow(DataIn) -- no data yet
SetLow(Latch) -- Close the Latch, this freeses the previous data
for i = 8,1,-1 do
-- the last bit is processed first, so it can shift to the end
SetLow(Clock) -- prepare for receiving a new bit
if (DataArray[i] == 0) then
SetLow(DataIn) -- when the bit is low, set the input low
SetHigh(DataIn) -- when the bit is high, set the input high
SetHigh(Clock) -- this changes makes the shift-register read the data-bit
SetLow(DataIn) -- reset the data-bit
end -- repeat for all 8 bits
SetLow(Clock) -- finishes the last read
SetHigh(Latch) -- Open the latch, this makes the input available on the output pins
ShiftOut({1,0,0,1,1,1,0,1})
print ("GpioTest ended")
mjdb
Use GPIO pins from LUA ... This way !
And I found the method to set gpio-pins directly from LUA. If you know it, it is soooo simple.
On the command line you can set a gpio-pin with a command: gpio write <pin> 1 or off gpio write <pin> 0
And, since you can execute shell-commands with the LUA command os.execute(<command>) you can set gpio-pins with the LUA command:
os.execute('gpio write <pin> 1')
You don't need to to export the gpio-pins from domoticz.sh or define gpio-switches in Domoticz.
Furthermore, the overhead from the os.execute is enough to give the shift-register time to process the new setting before a new gpio-command is executed.
I modified my demo-program. It uses the current Minute and Hour to a sort-of binary representation to show that the bits are really changing.
Please, be aware that the pins on the Raspberry Pi are different from the previous example.
Thank you all that have contributed to reach this point.
-- GpioTest
local LatchGpio = 21 -- pin 29 on Raspberry Pi
local ClockGpio = 22 -- pin 31 on Raspberry Pi
local DataGpio = 23 -- pin 33 on Raspberry Pi
-- This example uses a shift-register that has 8 outputs.
-- It is controlled from a Raspberry Pi with 3 gpio-pins.
-- __ __
-- Latch; pin 12 on the 74x595, purple
-- Clock; pin 11 on the 74x595, green
-- DataIn; pin 14 on the 74x595, brown
function SetGpioLow(Gpio)
local Cmd = 'gpio write ' .. tonumber(Gpio) .. ' 0'
os.execute(Cmd)
function SetGpioHigh(Gpio)
local Cmd = 'gpio write ' .. tonumber(Gpio) .. ' 1'
os.execute(Cmd)
SetGpioLow(LatchGpio) -- Freeses the current state of the shift-register
-- ShiftOut is used like: ShiftOut({bit1, bit2, bit3, bit4, bit5, bit6, bit7, bit8})
-- The bits are in fact integer values 0 or 1.
-- Example: ShiftOut({1, 0, 0, 1, 1, 1, 0, 1})
SetGpioLow(ClockGpio) -- start clean
SetGpioLow(DataGpio) -- no data yet
SetGpioLow(LatchGpio) -- Close the Latch, this freeses the previous data
for i = 8,1,-1 do
SetGpioLow(ClockGpio) -- prepare for receiving a new bit
SetGpioLow(DataGpio) -- when the bit is low, set the input low
SetGpioHigh(DataGpio) -- when the bit is high, set the input high
SetGpioHigh(ClockGpio) -- this change makes the shift-register read the data-bit
SetGpioLow(DataGpio) -- reset the data-bit
SetGpioLow(ClockGpio) -- finishes the last read
SetGpioHigh(LatchGpio) -- Open the latch, this makes the input available on the output pins
-- the function bitand is used only for the example
-- to get a binary representation of the time
function bitand(a, b)
local result = 0
local bitval = 1
while (a > 0) and (b > 0) do
if (a % 2 == 1) and (b % 2 == 1) then -- test the rightmost bits
result = result + bitval -- set the current bit
bitval = bitval * 2 -- shift left
a = math.floor(a/2) -- shift right
b = math.floor(b/2)
return result
local CurrMin = tonumber(os.date("%M"));
local CurrHour = tonumber(os.date("%H"));
ShiftOut({bitand(CurrMin, 1), bitand(CurrMin, 2), bitand(CurrMin, 4), bitand(CurrMin, 8), bitand(CurrMin, 16), bitand(CurrMin, 32), bitand(CurrHour, 1), bitand(CurrHour, 2)})
mjdb
Just to show, this is my led-panel.
Each led shows the status of a light, activity, door or window, machine etc. on three floors.
The (bigger) leds at the bottom show communication with Domoticz. The thingy is powered by a Raspberry Pi Zero W with Domoticz. The small black blocks are the shift-registers.
For the foto I used the test-button. It puts all leds on to see if they are functioning.
The "connection" from the Raspberry Pi to the other electronic stuff is done by opto-couplers. From the RaspPi-section to the rest there is no electrical connection.
Some people asked me why I need this. Well I don't.
ikkezelf
I see 2017, but very nice. I love to see you accomplishing this.
there is no question why.. just because it's possible.
Any progress and pictures of the end result?
